Rattling noise coming from exhaust.
I have a 1999 Chevy Blazer ls.
I have a rattling noise coming from my exhaust . Also I smell sulfur. The engine seems to be missing. When I but it in reverse the rearend shakes. This just started this morning. Please can anyone help |
Got any codes for your cat?
I bet the cat has broken, and the pieces are in the muffler. Explains the sulfur smell |
What about the engine and the rearend shaking I'm reverse???
What about the rearend shaking in reverse and the engine missfire.
Originally Posted by Trip coverage
(Post 707965)
Sounds like an easy fix?
I thought it could.be a rear end problem.
Any check engine lights?
The rear end shake could be a different problem, but let's narrow down if you got a bad cat or not |
Check engine light is on.
Yes ,the check engine light is on. Put it on a micro mechanic. It's junk.
I don't get paid untill Friday. I'll let you know.
Originally Posted by cleburne red
(Post 707971)
Thank you for your help.
I have had owned another blazer that had the same rattle. But it had no performance issues. Of course I had that one fixed as soon as I heard the rattle.
I let this rattle go for about a 1000 miles. I'm taking to my cheap exhaust mechanic first thing Friday. I really hope it's the catylitic converter that's causing these issues.
(Post 707971)
(Post 707987)
Thanks for your help.
Would I do any damage to "the blazer"
If I drove her to AutoZone with a busted cat. |
(Post 707990)
Thanks for helping me out
Originally Posted by odat
(Post 707992)
prob not - if back pressure got too high if the internals come's further apart it would just quit running due to lack of exhaust flow .......
(Post 707993)
Would the cat breaking up cause the rearend to shake???
(Post 707997)
Depending on what you mean by shake but A multi hard miss prob would
One more thing this all started with no warning. It almost seems like someone sabatoged my truck. |
(Post 708101)
just got it out of the exhaust shop. No symptom have been repair. With the exception of the rattle and the vibration of the rearend. It is still missing and popping.
(Post 708108)
OK, so the exhaust shop replaced the cat? And now the rattle and vibration is gone, but it still misses and runs rough?
Took it to AutoZone. It threw 5 codes 2 0300 0171. And 2 0101. The code reader says the blazer needs a fuel regulator. Which makes sense because half of air filter is missing. Me and buddy are now tear apart the carb(injectors) to replace this part. Hope this fixes it. |
Did you actually check the fuel pressure, or are you just throwing parts at it? Fuel pressure is super easy to replace, and can determine if the injectors or pump is at fault
This is what was recommended.
Don't know. |
If it helps we are in a full tooled logging shop.
I work in the logging industry. I have access to a full tooled shop. |
And all the computer readers are locked up. Don't have access to those.
You don;t need a code reader to check fuel pressure look at the sticky { how to check regulated fuel pressure } at the top of the second gen section and follow it step by step
Yeah, you can rent (for free) a fuel pressure tester at pretty much any parts store. Super easy to check. Can save you wasting money replacing the wrong part
(Post 707990)
(Post 708116)
Okay, yes the cat has been replaced with a straight pipe.
Took it to AutoZone. It threw 5 codes 2 0300 0171. And 2 0101. The code reader says the blazer needs a fuel regulator. Which makes sense because half of air filter is missing. Me and buddy are now tear apart the carb(injectors) to replace this part. Hope this fixes it. All above can be caused by a bad cat low fuel pressure and such. There is no code for a fuel regulator as the computer does not monitor fuel pressures - Fix the air cleaner, clean the maf with cleaner made for it and do the fuel pressure tests 100% as sticky tells you too before you replace anything and spend money you don't need too spend .... The failed cat was a easy guess now it's time to test and trouble shoot while you keep cash in wallet and wallet in hip pocket ...... |
(Post 708121)
Problem fixed. Check engine light is still on. Don't care. |
(Post 708328)
Switched out the cap and rotor .
