Rebuilt trans now has no 3rd or 4th gear.
Ok thanks im gonna drop the pan this weekend.
98 = 4L60E == no governor. The 3-4 servo is a plausible cause, but would not cause a loss of 3rd gear.
The No 3rd or 4th gear symptom chart lists the 2-3 shift solenoid valve as the item to check, checking for sediment in the valves, a faulty electrical connection, and/or a damaged seal.
The wiring can be quite easy to damage when installing the pan if one is not careful.
I believe kyle has alldata or something similiar, or maybe a paperback library? I supose he could have a secret blazer nome in a cage! I believe he used to have a bravada aswell?
Used to have a 2k Bravada (same thing as a Blazer). I still have all of my reference materials from that. Plus a LOT of books on transmissions, engines, etc. ATSG manuals FTW!
I dropped the pan today and removed the 2-3 solenoid. The seal appears to be fine and I am not seeing and sediment around the valve. I also removed the 1-2 to compare them. Is there a way to test if the solenoid fires or not while out of the valve body? Also are the solenoids interchangable to see if I lose 1-2 instead of 3 when swapping them?
I also pulled up codes from the PCM and I had no tranny codes. I had a p0102 MAF circuit low and a engine misfire code.
Both solenoids read around 21 ohms and with key on they are getting voltage. Any thing else to look for? I was looking on google for some suggestions and it said that there is a fuse for the transmission? I didnt see one in the fuse block though. I am prolly gonna bring it to a tranny shop now because this is as far as my knowledge goes lol.
greenhornet
04-28-2012 07:28 PM
gomfrddy
03-28-2012 06:27 PM
paul94blazer4x4
07-11-2011 06:01 PM
flowdog1972
05-30-2011 06:44 PM
