-   -   Removing the transmission (https://blazerforum.com/forum/engine-transmission-35/removing-transmission-82469/)
toadie 11-01-2013 09:15 AM
I have an ’02 Chevy Blazer and I need to replace the torque converter. I am having trouble getting to the top driver side bolt on the bell housing. Does anyone have any suggestions or secrets to accessing that bolt?
chris015 11-01-2013 09:23 AM
have you removed the trans mount cross member?? its a tight fit,but ive never had issues with getting to it. 90000ft of extensions is required lol.
1sttimejimmyowner 11-01-2013 11:39 AM
Its not all that bad ,remove your crossover lower the trans as far as it will go.Use about 1 and half feet of extension you should be able to get to the top bolt easy.Or you can climb on top of the engine and get it from there using a #14 wrench.
newguy 11-01-2013 01:51 PM
I know which one your talking about ,top left. you`ll need a swivel adapter for the socket. Take off crossmember and lower the back of the tranny slowly. theres a chance of breaking your distributor if you dont. should be able to get to it
chris015 11-01-2013 04:36 PM
oh yes! take off your cap to prevent breakin it.
abig84 11-01-2013 06:40 PM
i have a harbor freight socket wrench, maybe someone else has seen it, its about 18 inches, skinny and has a 1/4 inch on one end and a 3/8th ratchet on the other end. that 1/4 inch side, since its so small, with a 15mm socket can actually get in there to get it off. only once i couldnt get it off using that due to the motor mounts being so bad the engine actually came back a bit into the firewall
