-   -   Replacing engine flywheel/flexplate (https://blazerforum.com/forum/engine-transmission-35/replacing-engine-flywheel-flexplate-20063/)
jonesjamesw Apr 22, 2008 02:54 PM
Can anyone tell what a reasonable timeline would be for a trained/certified mechanic to charge for in labor for replacing an engine flywheel/flexplate in a 1997 blazer would be?
Thanks
JJ
blazinrebel Apr 22, 2008 04:47 PM
RE: Replacing engine flywheel/flexplate
is the truck manual or automatic
Hanr3 Apr 22, 2008 08:54 PM
8 hrs.
It will take 4 hours to remove the tranny and 4 hours to reinstall it. You can do it yourself if you have some mechanical experience. Searcht eh Do-It-yourself section for my thread on tranny removal. In this case there are a few things you can not do, however the tranny basically has to come out of the truck, or rahter slide back 4" or so you can get tools on the flexplate (automatic) and remove it. I use longer bolts to replace the tranny bolts and slide it back on the longer bolts. Howver you still have to remove the driveshafts, t-case, exhaust cross over pipe, torque converter, and unbolt the tranny from teh engine. Plus the wires and hoses attached.
jonesjamesw Apr 23, 2008 02:37 PM
automatic
tankie88 Apr 28, 2008 02:03 PM
I did my 85 M1009 blazer in 4.5 hours.Trans and transfer box as one unit,moved it back about 6 ins.
Hanr3 Apr 28, 2008 09:55 PM
that would be a bout right for a fullsize. you got a ton more space to play with then the S10 versions.
