-   -   Requirements to build 383gm stroker (https://blazerforum.com/forum/engine-transmission-35/requirements-build-383gm-stroker-83897/)
8ballrun17312 Jan 15, 2014 06:39 PM
What do I need to build a Chev 383 stroker for my 92 Chevy truck?
abig84 Jan 15, 2014 08:52 PM
i think its just a 350 block bored .030 over with a 400 sb crank. thats about all i know. probably better off having a machine shop build one
cleburne red Jan 15, 2014 11:41 PM
I used to daydream about building a 383 up for my chevelle. It's a 400 crank like was said. It has a 3.75" stroke, the 350 crank is 3.48". I found a decently priced forged rotating assembly on ebay a few years ago. It claimed to be balanced, but I think I would pay to have a machine shop double check it!
Whatever you do, paint the heads orange, and if you ever race anyone, tell them it's a 305, LOL!
Diaita Jan 16, 2014 12:14 AM
You need a 400 crank and balancer, the crank machined to fit and either different rods or pistons. I used stock rods and pistons with a higher wrist pin hole. I had it in my 91 S10. Some would believe it just had a custom exhaust. :D
Diaita Jan 16, 2014 12:16 AM
I can't remember if it was bored .030, or .060...
swartlkk Jan 16, 2014 06:22 AM
Step 1: CLICK HERE.
Step 2: Read.
Step 3: Do.
There are much better options out there than using a 400 crank, but none are cheaper than that. The easiest (and I would argue best) option is a balanced rotating assembly from any one of the performance outlets (either catalog or online).
