Hey forum, its been a while since ive posted, but ive still been browsing the site occasionaly
weird problem that seems quite common on any type of vehicle, is when taking a fairly quick right turn (is in not slow) my oil pressure drops right to 0 and stays there untill im done the turn and give it gas. After i give it gas it goes right back up to 275kpa which is half on the gauge. the needle does seem a little more jerky at idle. also bumps do not seem to affect it, or left turns. i havent seen it do it on a hard brake either. but i can make it do it pretty much every right turn, if im going fast enough. but enough ramble.....i have found the oil pressure sending unit, directly beneath the dist. i can just barely fit my hand in there, let alone see it, tried jiggling some wiring, but i dont think it helped.......if it was infact, the right wiring i was after..... but anyway, is there some sort of oil screen thats prone to clogging? hopefully not a spun bearing, or the oil pump....ugh i just did the fuel pump for the second time and now all 4 balljoints right before i have to go to school. im fairly religious with my oil changes, take good care of her, if that says anything about the oil quality.... or is it mostly likely a bad gound or sending unit? a bad ground would make me think it would also drop pressure over bumps etc. sorry for the ramble just trying to explain as best i can :) bump, no idea's? |
Please do not bump a thread after a mere 8.5 hours... The 24 hour rule was in place long before you dropped off the radar. :icon_wink:
Are you sure that it isn't just a bare wire contacting the frame on tight, quick turns? |
you know, i think it just might be!! I can feel what seems to be frayed wire on the end of the oil sending unit, just cant see the dang thing.
And i didnt drop off the radar, completly, i love you guys! lol this forum has been here for me for 5 years! I love enthusiasts. this place is very helpful to me. thanks kyle, ill try my best to do a follow up, got it booked in for thursday morning for balljoints anyway. p.s what happend to 'bold' and 'italiqes' or however you spell it, i need emphasis! lol |
You may need to turn on the enhanced editor in your User CP --> Settings & Options --> Edit Options. It's all the way down at the bottom. Otherwise, you can use bolt by using the [B] tag and italics by using the [I] tags. Just don't forget to close them.
| All times are GMT -5. The time now is 01:30 AM. |
