rod bearings
Old Apr 24, 2008 | 01:48 PM
blazinrebel's Avatar
blazinrebel is an unknown quantity at this point
Default rod bearings
has anyone here ever replaced the rod bearing with out removing the engine from the truck. if so how would i go about doing this. i have a rod knock that is steadily getting worse and i want to fix it before it ruins my engine.
Old Apr 24, 2008 | 05:42 PM
Default RE: rod bearings
If you can get the pan out, it is possible. Not going to be easy, but possible.
You would remove the pan. Remove the rod caps two at a time, marking them for their location (cylinder #). Check the crank for scoring and polish as necessary. If you can, mic the crank and check for out of tolerance on the journal as well as out of round. If you find out of tolerance, but still round, get the appropriate thicker bearings. If out of round, pull the engine. Now, if everything is good, replace the bearings on the rods, using ample amounts of assembly lube. Torque to spec and repeat on the next journal back until done.
Again, if you find that you have anything out of round or score marks in the crank that you can catch your finger nail on, you need to pull the motor and either cut the crank or replace it.
Nuikala
Jun 25, 2012 02:08 PM
ceanern
Jun 25, 2012 12:44 PM
atvwarrior
Dec 1, 2011 06:15 PM
chevygonzalez
Oct 31, 2010 08:11 PM
atomicturd
Jan 21, 2010 12:11 PM
