-   -   roller tip rockers? (https://blazerforum.com/forum/engine-transmission-35/roller-tip-rockers-29851/)
stlarry 04-21-2009 09:11 AM
roller tip rockers?
i have a 4.3 in my 85 blazer. lots of mods. i also have another 4.3 with the same mods with one addition. roller rockers. i am wondering if i can just pull out the rockers and swap them.
also, what advantage do roller rockers give me?
swartlkk 04-21-2009 12:20 PM
Depends on the rocker and how it is attached to the head. If your head has pressed in studs... I would not trust them, especially if you have increased the spring rate (different valve springs) or seat pressure (shimmed your springs).
As far as the benefits of roller rockers. Well #1 is reduced valve train friction. There are more, but a quick google search should turn up more than enough reading material to suit your needs.
