roller tip rockers?
Old Apr 21, 2009 | 09:11 AM
stlarry's Avatar
stlarry is on a distinguished road
Default roller tip rockers?
i have a 4.3 in my 85 blazer. lots of mods. i also have another 4.3 with the same mods with one addition. roller rockers. i am wondering if i can just pull out the rockers and swap them.
also, what advantage do roller rockers give me?
Old Apr 21, 2009 | 12:20 PM
Depends on the rocker and how it is attached to the head. If your head has pressed in studs... I would not trust them, especially if you have increased the spring rate (different valve springs) or seat pressure (shimmed your springs).
As far as the benefits of roller rockers. Well #1 is reduced valve train friction. There are more, but a quick google search should turn up more than enough reading material to suit your needs.
AlphaCrow
Mar 19, 2015 05:00 PM
madhatter256
Feb 20, 2009 09:56 AM
97ssblazer
Performance & Brainstorming
Feb 7, 2009 09:36 PM
smdepew1976
Engine & Internal
Jan 7, 2007 12:01 PM
1996BZR
Engine & Internal
May 18, 2006 12:39 AM
