-   -   rotor (https://blazerforum.com/forum/engine-transmission-35/rotor-28054/)
banshee386 02-26-2009 05:37 PM
rotor
Im having trouble installing my rotor back into my engine it's a 1995 blazer Vin w i marked it with paint before i took it out and now when i go to drop it in how it was it will only drop in way ahead of my marks i tried wiggling it and shakeing it any idea's ?
swartlkk 02-26-2009 07:50 PM
RE: rotor
Sounds like you are one tooth off with the distributor. The oil pump drive shaft is likely hanging you up because it is not in the proper position. It is going to be fun...
banshee386 02-26-2009 10:06 PM
RE: rotor
yea thats what i was thinking is there a way to move the oil pump drive to line it up better so it'll fix in there its to far back to be able to look down into the hole so i cant see any thing
swartlkk 02-27-2009 06:49 AM
RE: rotor
Get a mirror and a long, slender screw driver. You need good lighting as well.
rowe 03-01-2009 03:23 PM
RE: rotor
wow,,,im glad i looked at this post.
doesnt sound to good when ur having problems
just putting a rotor in.
no pun intended.
swartlkk 03-01-2009 04:36 PM
RE: rotor
If you were just changing the rotor, this would not happen. But I believe the OP stated rotor when actually speaking of the distributor.
