Rough start
When I start the the engine, the whole truck shakes really hard but after the start it is fine. HELLLLPPP!!!
RE: Rough start
Does the shaking go away after you give it gas?
Sounds like it starving for fuel during start up. Turn the key to run, but not start for a second, then turn it too start and see if that makes a difference. |
RE: Rough start
Another idea...Have you checked the motor and transmission mounts to make sure they are not broken?
RE: Rough start
Yeah the it only shakes when I start it then it is fine. I've tried just turning the key on for a second then starting and it acts the same. I will be checking the engine and motor mounts now though. I've thought of that but I thought if it was the mounts it would shake while at high speeds as well.
RE: Rough start
ORIGINAL: bradgfp0084 ...I've thought of that but I thought if it was the mounts it would shake while at high speeds as well. |
I know its old, but what was the solution? i'm having the same problem, rough at startup, check engine light comes on; sometimes it smooths out after a few seconds, sometimes longer. thanks!
The CEL is trying to tell you something...
And why would you dig up a 2+ year old thread that has no resolutions posted in it when there are more than a few other threads discussing this topic and similar ones with trouble shooting steps, etc... |
because this just happened to be the exact problems that im facing. i saw similar, but not exact problems in other threads. figured it was easier to resurrect and old one as opposed to starting a new one.
any answers? |
| All times are GMT -5. The time now is 10:22 AM. |
