RPMs at 70mph?
Old Mar 13, 2012 | 09:35 PM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default RPMs at 70mph?
Just want to compare. My 4x4 Blazer 4 door runs at 2500 RPM at 70mph, seems a bit high to me, but it could be normal, just want what you have to say
Old Mar 13, 2012 | 09:50 PM
Blazer_LT's Avatar
Blazer_LT is on a distinguished road
my 2000 4 dr 4x4 runs that too. 2000 and tho i dont do it often, and 60 is around 2000. i am usually doing less than 45 as the quickest route to anywhere from here is the back roads.
Old Mar 13, 2012 | 10:03 PM
chris015's Avatar
Mine is 2650ish at 75. thats with 235 65 16 tires and 3.42 gears.
Old Mar 13, 2012 | 10:12 PM
pettyfog's Avatar
My Brava does about 2350. But according to my GPS, the speedo is approx 1 mph slow.
Factory spec tire size, Firestone Destination AT
I havent checked the tach against the scan tool yet. Suggest you may want to calibrate both that way.
Old Mar 13, 2012 | 10:19 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Mine was about 2500 as well. then after i got my PCM tune it was at 2300 and now with 31's its at about 2200 at 70. That is with 3.73 gears also.
And petty, my speedo used to do the same thing and i think thats because most of our trucks are calibrated for the 235/70/15's. After i got my PCM tuned for my tire size it was dead on.
Old Mar 14, 2012 | 06:10 AM
smaiwald's Avatar
smaiwald is on a distinguished road
My ZR2 is at 2000 rpm for 70. Thats with the stock 3.73 gear and 31" ATs
Old Mar 14, 2012 | 10:07 AM
Ok, thanks all. I plan doing a small lift and putting on 31s. How do I get my PCM and speedometer gauged up?
Old Mar 14, 2012 | 12:08 PM
There are parameters in the PCM concerning the gear ratio & tire diameter. Being that you have a '95, your options are limited and really depend on what you have in it for a PCM. Three different PCM configurations were used throughout the '95 production year.
BTW, please either create a garage for your vehicle, list it in your signature & attach to your posts, or at the very least post the vehicle information in your original post. It gets old looking for vehicle information!
Old Mar 15, 2012 | 10:20 AM
Tinted's Avatar
Tinted is on a distinguished road
mine is just above 2000, with 31's on and about 2 inches of lift.
lift and bigger tires will eat into your fuel economy, it did for me anyways.
Old Mar 15, 2012 | 11:12 AM
Xenon's Avatar
Xenon is on a distinguished road
mine is about 2200 rpm at 70... 3.73s and 235/75/15s
Hizapitt
Apr 24, 2010 02:39 PM
Turismo
Sep 27, 2009 11:30 AM
Scooterewski
Jun 2, 2008 09:21 PM
Xtreme Blizz
Aug 2, 2007 04:23 PM
mattbbb14
Mar 23, 2006 09:46 PM
