-   -   runs good at high speeds not at idle. (https://blazerforum.com/forum/engine-transmission-35/runs-good-high-speeds-not-idle-60638/)
dmerski Jun 30, 2011 09:40 AM
95 Blazer runs good at high speeds but sugers and misses at idle.Change plugs,wires,MAP and all sensors on uper intake manfold.
maddie's dad Jun 30, 2011 01:45 PM
Check for a vaccuum leak. Use a can of carb cleaner or starting fluid. Spray short bursts at suspected leaks, and if the idle speeds up, you have found your leak.
