S10 Stalls when cold
I have a 1998 S10 with the 2.2 . Just recently its started running rough and almost stalls till it reaches operating temperature . After it warms up if runs fine . I seen where it might be the coolant sensor . Any help is appreciated . Thanks
I currently have the same issue with an '89 S15. Had a complete tune up including a new distributor, new fuel filter, injectors, etc were cleaned, new fuel pump relay. The fuel pressure is good at 10 PSI. It does run better, but still rough and sometimes dies when put in reverse after a cold start. Did you find out what your problem was?
Yes i got bad gas . Several in my area having the same issue . The gas station is going to make it good . Taking to my mechanic. Just one big pain in the butt.
Originally Posted by Lowered89
(Post 688815)
Originally Posted by Joe Alphin
(Post 688834)
Originally Posted by Keystone40
(Post 688839)
Almost sounds like it might not be running on all cylinders - did your tuneup include new plugs and wires? Are all the wires seated/connected properly on the plugs? Are they decent quality?
| All times are GMT -5. The time now is 09:33 AM. |
