-   -   Sea foam (https://blazerforum.com/forum/engine-transmission-35/sea-foam-82322/)
charliebrown 10-24-2013 11:37 PM
Sea foam
HI,I am running some sea foam thru fuel system and it was suggested to leave old filter in fuel line to catch any garbage in fuel system before putting on new filter.
I am also thinking about using a bottle to catch what might be in fuel lines
by cycling fuel pump to get anything that might just before new fuel filter
any thoughts on this would be appreciated,thanks
newguy 10-25-2013 02:47 AM
I would just put it in the tank and run a tank fuul then change the filter. Seafoam does its work when its just sitting
ol' grouch 10-25-2013 06:54 PM
I've used Sea Foam in really nasty systems. It will clean things out pretty well. The only thing I haven't seen it do is get into heavily clogged idle passages in carburetors. It can really fill up a fuel filter with gooky stuff (<---------fancy technical term) and stop it up. By keeping the old filter in there, you're filling up what you plan to throw away anyway. This way, when you put a new filter on, it should last a while as most of the garbage went with the old one.
10-78 edac 11-21-2015 01:56 PM
Don't use too much
Sea Foam Wreaks Havoc on England Coast Causing Problems for Motorists - Trending Now - AccuWeather Videos
TonyZR2 06-23-2018 05:27 PM
Sea Foam right now at NAPA is $7.99 CAN.!!! :icon_eek: Never seen it that low.
