seafoam 00 4.3
seafoam 00 4.3
i just seafoamed my 00 4.3 and if anybody has heard of this you know whats suppose to do.. problem here is that mine didnt smoke like it should have. after i poured it into the vacuum line i noticed a wet spot behind my tail pipe. run it down the road and back and nothing happened..
Seafoam spray and straw
From what ive read I believe that when you use the vac line method it dont get to all cylinders, just the back 2... I think. Seafaom makes a spray that you can spray into the intake from the throttle body. You have to email seafoam to get a special straw, but they sent me 4 for free. You spray it and let it sit for a few minutes and start it and run it. here is a link to the website. Sea Foam | How to Use Sea Foam Spray | General Content - Sea Foam Spray hope it helps
