Seafoam Pros and Cons??
Hello i was wondering about the pros and cons of seafoam, could it make any thing worse? or will it only help??
RE: Seafoam Pros and Cons??
Its always help my vehicles run smoother i never had any bad things with it,
I've heard its also good with your Wheaties in the morning :) |
It works great makes your truck run alot better it most cases but it can also foul your spark plugs. Alot of people suggest you changes them after you do it. I havent and i have done it twice with no problems.
Try a search or two on the subject. It has been discussed many times in the past.
I only use the stuff down through the intake. I have never used anything in the oil as a good oil will clean out junk too. I think that Chevron Techron Fuel System Treatment Plus is better as a fuel injector cleaner. For use as an upper engine cleaner, it works very well. |
ok thankyou all!!:)
oh wait one question how much is a set of plugs and how how hard are they to install
sorry im only 15 so im learning as i go |
You should be looking at getting a set of AC Delco Double Platinum plugs (41-993). A set will run about $40.
and MOST of the plugs arent that bad. but one will be a PITA.
i think is time to replace the plugs anyway but to suck up the seafoam do 1/2 trought brake booster and 1/2 in the tank right, you dont relly need it in the oil cause a good oil all ready cleans good???????
I prefer BG44K to Seafoam. Changing out the number 3 plug will be a new exercise in profanity for those new to blazers.[:@]
| All times are GMT -5. The time now is 08:42 AM. |
