Shift problems on rebuilt trans 2000 blazer
Old 10-14-2018, 10:13 PM
Caleb Lav's Avatar
Caleb Lav is on a distinguished road
Default Shift problems on rebuilt trans 2000 blazer
So I just did a transmission swap to a rebuilt one but I can only start in neutral not In park, also when in D it will not shift through the gears,but i can shift between gears fine manually, will need a new shift linkage it is broken so not on correctly, says Rervese when in Park but I can shift into reverse neutral 1st, 2nd, I think it won’t go into 3rd because of shift linkage but when in D it will not shift at all, could this be the transmission I just bought? Ps: When I go Under the truck and turn manually I can go through every gear
Old 10-15-2018, 12:09 AM
christine_208 will become famous soon enough
This is a shot in the dark but we have an expert here who likely can tell you what: I've heard of shift levers on the transmission being installed backwards. Sounds crazy but there it is.
Old 10-15-2018, 12:20 AM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
Mine was doing pretty much the same thing. I had the shift cable replaced and it works fine now.
Old 10-15-2018, 07:31 AM
Caleb Lav's Avatar
Golf addict, so yours wouldn’t shift in drive through the gears? I feel like the shift link has nothing to do with that
Old 10-15-2018, 03:33 PM
Transman304's Avatar
Did you use the MLPS off of the old transmission? If you did it’s more than likely broken.
Old 10-15-2018, 05:17 PM
G0LFADD1CT's Avatar
I could shift into reverse, neutral, and drive. Nothing else. My shift cable was messed up pretty bad. If I disconnected it from the tranny I could manually hit all positions.
Old 10-15-2018, 05:40 PM
Caleb Lav's Avatar
i did use the old one I will get a new one along with a shift linkage this week hopefully it fixes my problems just hoping I don’t have to drop the trans again
JAYS1998BLAZER
07-31-2011 12:35 PM
hemivette
05-15-2010 06:46 AM
bowtie lifer
08-09-2009 08:16 AM
rickyhj2002
12-30-2008 10:36 AM
blazin97
12-22-2007 03:22 PM
Quick Reply: Shift problems on rebuilt trans 2000 blazer
