Slipping auto trans 95 4wd
My automatictranny on my 95 seems to be slipping a little at high revs, it will almost redline the tach if I dont let off the gas, it has only happened three times, also it seems to be going in and out of overdrive when I go highway speed, about 65???
Any ideas what to do first, perhaps an additive???
Lucas tranny fix.
Although you will need to save your $100 for the rebuild that is coming your way. No fluid change or additivewill fix a tranny problem. They are temporary solutions at best.
Well what I first thought was a fuel problem, hard to tell due to being mostly deaf and going by feel alone until the slipping happened, So I check my tranny fluid yesterday and it is 2 qts low and I dont have a leak, I take it to EZ lube every 4 weeks and they said it was fine, last time I'll trust them, perhaps thats why they are getting sued, this problem has been going on thru 3 oilchanges where they promise to top off the fluids. I'm sure there are good people working at some EZ lubes but not at the one by my home in Laguna Niguel Ca. I paid for a new fuel filter change and later found the original still on the car when I went to a differient EZ lube and they said I needed a new one a month later. NO MORE EZ LUBE FOR ME!
It is working much better now, did running it that low do dammage?
Is there an adjustment possible to get it to shift a little firmer, I carry a load in it every day?
2qts so it wasnt even up to the dip stick. Before you checked it did you do a 10 second hold in each gear and then back so the fluid would go everywhere it should. I think it outlines it in the manual. Does the fluid smell burnt or look discolored now?
It wasnt on the stick, I followed the directions in the manual to be sure and put in a pint at a time and repeated the process again until full, it smells ok and is working good now, I hope I caught it in time. Thanks for the help!!!
Lack of fluid will cause tranny problems. Keep on eye on it. Trannys don't use up fluid. If your low its going somewhere. If your not seeing it on the ground, under the truck on the frame, in the oil, in the coolant, it will be going into your t-case. Let ti go too long and you will have HVAC problems. Keep an eye on it.
