Slipping trans.
I have a 96 blazer, auto trans, was driving the other day and the rpms all the sudden skyrocketed and my car slowed to a stop in the middle of the road. i shut the car off, put some Lucas stop slip in it, started it up, headed on my way, and it did the same thing about 250 yards down the road. i did this 4 or 5 times until i got it home and parked it. does this sound like a possible plugged filter?
I have the same problem I don't know what is wrong with it all the rest of my gears are ok. Does your blazer shift good when cold then slip when hot?
it does it when cold and hot, i haven't been driving it since that happened though, it wont even get up to a cruising speed.
Did you actaully check your ATF level, warm.. in park?
I believe in Lucas for slips, but if it happened all of of a sudden it wont help. If slip comes on gradually, Lucas takes a couple hundred miles to work. You have another problem than clutch/band slip. Take it to to good shop and have the pump pressures checked. |
Yes, i checked the fluid, i'm going to flush the fluid and replace the filter, if that doesn't fix it i'm replacing the tranny with a 5-speed.
Originally Posted by RedSquirrel
(Post 500103)
if that doesn't fix it i'm replacing the tranny with a 5-speed. :icon_lurk5: |
if replacing the filter doesnt work then, to me, the transmission is not worth fixing. the automatic transmissions in blazers are known for having problems, and once the start they dont stop. i would rather have the 5-speed anyways.
(Post 500147)
and once the start they dont stop. i would rather have the 5-speed anyways. ;) |
| All times are GMT -5. The time now is 01:20 AM. |
