sputter into second gear
Hey guys iv got a blazer problem yeah dont we all? Hah okay so ONLY COLD will my blazer sputter going from first to second gear if i give it alot more gas then normal it wont do it but just a normal cruise off the line it will sputter, iv already replaced fuel filter and giveing it a full tuneup (it had to be done anyways) it only happens when the truck is cold any ideas???
And my fuel pressure has been checked and is fine
I'm having a similar issue, did you ever find the cause?
Thanks, RAP |
make sure the air induction system is tight,,,no leaks from the air box to the TBI
| All times are GMT -5. The time now is 08:58 AM. |
