| jeander12 |
01-05-2013 05:35 PM |
start up issue
iv got a 91 blazer 4.3 tbi, it ran great when i drove it 2 see my girlfriend 1 day, until the battery died. the battery died and it wouldnt hold a charge so i would have 2 jump it off. then 1 nyte after jumping the truck off 2 leave my buddies house the truck cuts of and it wont start up. i replaced the battery, and when i did i found that my distributor had come loose. check the ignition coil and it was bad so i replaced it along with new plugs and wires and still no start. and i have already read the thread about egine cranking but no start but i was just looking 4 some other feed back. i have spark i tested visually with crank it with a plug connected 2 a wire but outside of the block, i hear the fuel pump kick on and i can see the injectors spraying while turning over, and the timing chain isnt broken. iv checked the normal things i know to check i really would appreciate some help cause i miss and need my truck.
