-   -   starter pinion gear (https://blazerforum.com/forum/engine-transmission-35/starter-pinion-gear-75200/)
richphotos Nov 16, 2012 07:22 AM
starter pinion gear
Okay, so I have heard this problem before when I had my 94, it did it occasionally but never was a problem the 2 years that I had it. so I'm wondering if I should even worry about it on the Jimmy.
Anyways. Went out to start it this morning to let it warm up. Turned the key and I heard the starter engage, but it did not crank the engine. So I turned the key off, and turned it back on and it started perfectly.
From my google search, I came to that it is the starter pinion gear.
Is this something that can be lubed? or is the starter on its way out?
like I said, my 94 did this every once in awhile (especially when cold) for 2 years.
matthewp Nov 16, 2012 07:43 AM
Pull the starter and inspect it for damaged gear teeth and do the same thing for flywheel (manual trans.)/flexplate (automatic trans.). It's rare for gear teeth to be damaged, but it can happen.
Usually the stater overrun clutch is what goes out. The overrun clutch allows the starter to turn the engine over, until the engine starts and the clutch allows starter gear to spin faster without damaging the starter until you take pressure off of the key. Some older vehicles have starter rebuild kits if your up for the challenge, there are also repair shops that rebuild alternators and starters for older vehicles.
If the everything else is good the last thing that could be the issue is the starter not engaging correctly to the flywheel. Some older GM vehicles have shims between the starter and the engine that allow the starter gear to engage correctly to the flywheel. All it takes is a little time and the special measuring tool just for this job.
richphotos Nov 16, 2012 02:59 PM
But the starter seems fine, The reason I ask if there is something I can lube is because when I had my 94, it did this same thing, only when it was cold (below 30 degrees) and even after 2 years and 60k miles, it still started perfectly 97% of the time.
05BlackJimmy Nov 16, 2012 03:36 PM
Yes you can lube the pinion drive, it just involves taking off the starter and taking it apart, not too hard of a job just remember what goes where. But if the engine didn't attempt to crank it could be the pull in winding not engaging.
richphotos Nov 16, 2012 04:07 PM
Yeah the engine didnt attempt to crank, all I heard was the starter spin up, then I turned off the key, turned it again and it fired right up. I guess I will see how long it goes for until I need to have it rebuilt LOL! After all, 2 years and 60k miles on the blazer.
Thanks for all the help, I will find this and update it if I ever fix the problem if it gets worse or just goes poot.
richphotos Nov 18, 2012 10:31 AM
Here is a video of what it is doing
I think the starter is going bye bye, might replace it today.
http://i874.photobucket.com/albums/a...h_DSC_5781.jpg
05BlackJimmy Nov 18, 2012 03:14 PM
sounds to me like its cranking fine, if the starter pinion wasn't engaging it would click really fast. Disable the fuel and ignition and do a voltage drop between the battery and starter and starter and ground.
richphotos Nov 18, 2012 05:19 PM
I did the starter, it would crank fine, when it would actually crank the engine.
The new starter is working perfect. The other one was in bad shape. Looked to be original to the truck LOL
Captain Hook Nov 18, 2012 10:13 PM
Here's the problem part: Buy BWD Starter Drive SD1644 at Advance Auto Parts
When it fails, the starter motor operates, (free wheels) but the drive unit does not engage with the flywheel/flexplate.
richphotos Nov 18, 2012 10:32 PM
Yup, interesting note, on the old starter, I was inspecting the gear teeth for damage just to make sure that was not the problem, and i was able to spin that VERY easily. Was not able to do that on the new one.
Was pretty easy doing the starter, Minus the small A$$ area to unhook the solenoid, and the nuts on them being so corroded (on the solenoid wire mounts)
