Starting my Blazer Drive Train Rebuild - Need Advice
I'm Starting to rebuild my 99' Blazer Im not sure what I'm going to encounter but I know the engine needs work because its a 6cyl that has the power of a 4Cyl, the transmission shifts like a lose rubber band and the suppression feels like I'm riding on a waterbed. Im pulling the engine, transmission and rear axle to rebuild them all.
Im looking for advice on what Kits to use for the Transmission and Engine,
Engine - Using only summit racing as an example I'm having problems finding a "total" rebuild kit. When I search under my truck it only comes up with gasket and re-ring kits. I'm looking to replace the pistons, oil pump, freeze plugs.... When i search for only a 4.3L rebuild kit I find some but How do i know if they will work?
Transmission - On summit racing there are about 10 different transmission kits to chose from for the 4L60E. There's "master race", "Pro Super", "Premium Race", "lockup"... I'm not sure which one to pick. Im Just putting the V6 back to stock so I don't need a super transmission. Im guessing the lockup will work? Sadly its also the most expensive kit at $700, I'm also going to replace the shift solenoids.
Also if you need a new cam and lifters thats going to set you back close to $400 smack a roos
Thats actualy not true depending on which factory your engine was made Either Romulus Mi or Tanawanda New York these engines used different cranks and rods.Also 5 different pistons were used through out the years of 4.3 manufactured engines.The Z or W engine will tell you which block you have.
You can use a tanawanda crank,rods and pistons in a romulus block and visa versa but you cant mix and match rods and cranks.
Also gm used lighter weight cranks or heavy cranks in these engines.The with pistons.Even though the 350 is the same bore you cant use them in the 4.3 because the skirts are longer and would hit the counter balances on the crank.It would be posible is the skirts were trimed down and each piston balanced.Also the made engines with the x crank and rods and pistons which were heavy duty versions of these engines.Also the pistons used in the cyclone and typhoon versions had a deeper dish with lower compression because of the turbo chargers and inter coolers.They also made non balance shaft engines along with engines that have the balance shaft.So as you can tell theres alot of differences between engines that were made over the years.
joejiz
65
Apr 15, 2014 07:58 PM
gearheadone
May 1, 2013 09:58 PM
