starting problem
2001 blzr has not started the easiest all yr. 2-3 cranks. now that the temp. has gotten cold in IL. have to shoot little shot of starting fluid, starts right up runs fine. seems like it is not getting it's initial shot of fuel on it's own to start. Any ideas??????????????? 4.3 L
[sm=welcomesign.gif]to the Forum. As you suspect, requiring a shot of fluid to start can point to a fuel supply problem. If you use the 'search' function and look for 'test fuel pressure', or something similar, you will find a lot of posts detailing how to check it.
cgrett
Nov 15, 2010 09:08 PM
Sprocket
Mar 20, 2008 09:39 PM
mickey2001
Mar 13, 2006 11:51 AM
