Starts perfectly but then has no power
I need some help guys. 2001 s10 Blazer zr2 4.3. Was running find then started to run rough and missing. Quit on me had to get towed! The usually thought fuel pump but no 62 psi and held at 57-58 for a good 15 min. Pulled the dizzy cap off and found the problem. One of the screws that holds the rotor on had worked loose and then broke the rotor and when the screw came all the way out of course the rotor was flopping around so there goes the timing. Installed a new cap and rotor and it started right up and in the driveway it idled and revved up perfectly. Shut it off,buttoned everything up and took a test spin. Just out of the driveway it started to sputter wouldn't go over 10 mph and only about 1700 rpm. Babbied it back home and scanned it and got back two codes. PO 303 #3 misfire and a PO 101 mass air flow. Checked spark on #3 good. Cleaned MAF with MAF cleaner. It starts perfectly but still no power. Step on the gas it kind of shutters. Help me out guys. Thanks in advance.
Try unpluging the MAF connector, if better, suggest a new one. How is the fuel filter?
One thing tho, check the wiring to the MAF,
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAYAAAAGrCAIAAAB GztcdAAAgAElEQVR4nO2d27msKhCEDWQCmUQMxEBMhEAMxEQ8D 7Wt04ubeEWd+h/WN8txEBHKpoGmmYQQohJN7QwIIX4XCZAQohoSICFENSRAQohqS ICEENWQAAkhqiEBEkJUQwIkhKiGBEgIUQ0JkBCiGhIgIUQ1JEB CiGpIgIQQ1ZAACSGqIQESQlRDAiSEqIYEyKfv+7Zt27bt+54Hh 2FoZ8ZxvCYn4ziGObGZKUzHOdfGGIYBSXnpH0jXdV3X2TzgX2B LNZVnr7THcXQxUFaLNzIMQ9d10VIVVZAA+bRt28zwoHOOB51z1 +TEXtS2Qx4vTMfekQVNt2maci3bkH8ojs0D78XeoPfbz+eD417 eMvfS933+6YS//Xw+l71ORBQJkI+tpqzN3+83JUCZGhz9Cu/wkpx0XceLWsOBVkDR/cx39P1+PathmiXgDAEax/Hz+Xw+H5sHrwCjWj/9Fabv9xt+9fl8PGtuHMdxHPFVND/8Yd/3uH1o3EniKwqRAPnYVoHaiZrttZ9xHK0qfb9fyo0Vjs/nw/Y2DANf7N5PQoZhYB68djgMw/f75RFkwzlnD4Z3FG1poQCxB9q2LXOOg+yzsAc3zd2osDvjpYw8 eG3elqr9LQqQxWulFl+lVAPfRvtW4Z16PdlxHLuuQxny7qa5M9 j3fd/33++36zp+hV+xxLqusw809RVLDN1Gm9oPIgHyYXNlfeXL07YH/ItXsW1X9hVNJUIl42moyvnXL9L5fr9UItskbKNt/pK6I88CQmpRmbBA0ZgZe3UYZSlFQFJWs7xS5X15d0e5d86Fiec FKGPQ2WzDZ2S/hb1m8/P5fJClaKePL6HwV0jZe9k05lXkVSdr2/4gEiAfNhJ8mEy1ZuXjyxO1zdZ7vr1pIKC6s131fT8MA7pRmbef VShPraICxAaTuiMPK5f2M1sX/0WG8RnZtimgIYVGh00qU6rUaJ7J9hne6fS3d+bdi/dbD89ixWk0TKzCTn9tRqaJM+2ziP4KRUHRx7O2ZqwtwFAKfw0J kA8rHyoKrGi0PdtUYLGH/TXvxQ67w6ZMPGPewkS8dya+jQpQ5kXK7o91moQ+oLy5gYbX933 XdZ/P5/v9ok16AuHlPyxVuoqRuKd6098WzvR5d3kB4vmpVo3+lLVNUKpe ESEPVi88jfMkG10z3gKzwecbKnjKV/VrSIB8PAFCfUWFY1Oh7Y23qNd0YR95WjMZp4BX+0PQSkPwdo0K UGZQudAHFJ5mv0WW0DitOkdTDi0XFlGmVKdAvkOJWfSa29Qy4F nwZD4U3B2xNx7NgPegYYdGhyl5rVNHHh+HBMjHtkOvAXh1iLa3 raOQGFpJTA2qxDc5a3/4rvZ83mE7PEmAQjWJdjesjkCFo8YXckUTwCtV6zWzkpFSXhZUo QCFpRp1HvHS3re2g5yxgOzJMAzxVYkFJAECEiAfWxf5fkPz9gQ IY7psM7YZwzLq+55NlJXy+/3SCR21gKgvtoNmBSsqQJl3fqEA2XE3axQwZeuGtyoZ7Uji5NAH NJk5DfjWfg59814vLN96M70bz/OCQcNmdu7YB8qvQjfZFOu0cjTTKjj7dLhW6AOSAAEJkE9oFPCN apsK2ye6EmyK8A01BhoIGD7ncTqqPVit7UHbDj0B8pp6SKEATT EPizWseF/41zpKQjI9l1SpUgE9a86+EkoEKPVtaF7ZSRLeU2tjIwxTINmpo a6oz7vQiPspJEDbGccxM4yFhQ7bUo7+lgNq29IshB2K6Fi1Hbl DfvJ+dMqT91vvh3YMPn+D+dHDzDwg+3P0hVM36KUf3nVrZkhl5 gFNs8/b+qcXb+HXkACJs4DldVlLg5GYssjEPZEAibPAWOFlfY3FtWDih kiAxImUL3zbDwYErrmWOAoJkBCiGhIgIUQ19gqQjSm1B4wUHA5 jL3hgFYW9KAaeoienjp/HhqEujB95uU2F7wq5z6CMvXdMa+Bwm5N/53XsFSAXW5sjxNkg2ND11029QfkVFnMgrMeGTB7yOl/EZhKfo/n0Fqak2ON6O0aA9r+a7BQM+947ddpLuYFQbkekjo8zJRm73uay YYCidDNYj4qfnGS3ZihvY8itbSRRc9geT52zLQPbQMv3lsuefd EUVkCjYrQYVWaRvQKETOxMRAjxUOoLUFMcnFgI8TIkQEKIOmD2 +Z6gjhIgIcRG3G4XsARICLERCZAQohoSICFENSRAQohqSICEEN WQAAkhqiEBEkJUQwIkhKiGBEgIUQ0JkBCiGhIgIUQ1JEBCiGpI gIQQ1ZAACSGqIQESQlRDAiSEqIYESAhRDURElAAJISogARJCVE MCJISoiQRICFENCZAQohoSICFENSRAQohqSICEENWQAAkhqiEB EkJUQwIkhKiGBEgIUQ0JkBCiGhIgIUQ1JEBCiGpIgIQQ1ZAACS GqIQESQlRDAiSEqIYESAhRjVsI0DiOO9MRQjwRCZAQohqVBahp mu/3uzMRsZNhGJxzbZbvTNM0TdN8ZvD5+/3mf34Bfd875/Qyexb1Baht252JiD1AU3Y2fgrTWiBhR+mXqtPjqC9AsoAqAu0Y hqF2Ro5hGAZoWe2MiCKwLc+e6neAAGkUrBbDMOx8/9wQ3NRrJPXdYGvmPSlIgJ7NKwtfHbGnIAH6dV5Z+BKgpyAB+nV eWfgSoKcgAfp1Xln4EqCnIAH6dV5Z+BKgpyAB+nVeWfgSoKdQX 4AwgW1nImIzryx8CdBTqC9ArVbDV+WVhS8BegoSoF9nT+G3bdt 1HVdUpJZoRBdMfL9fLMLAv97iDOfcrun5ml7/ECRAv87mwufiL4hF3/eHLOaiQkGJNt+UKtUjwFKMPSlIgJ7NtsKH4XPqcge8G7cZMnvE S1wJBGhPAAMJ0LPZVvjXOFn6vt+cPVWqpyAL6KfZ3MKvWe25LX saWn0QsoB+ms0CdHhODrwQ3NuHZ0acQeVwHBKgumwWoL7vD89M 9EIbfqVK9SBkAf00m1v4BePcm8doVakehCygn2Zb4UMauq7D52 EYDncJjeOIUNMbfqtK9SCaO+yKsTMRUUh0xs22pLqug6slRf7b Ej6fzzbjvJ2DQ5OXRX18ExKg9wODJcXOlI+aiNh1HT9jf4vNuW qD2dXggqkDYi0SoJeD2TRt20Z7Sa8s/GilQqzoa3znohwJ0MvJO4xfWfipSgUN0sZht0IC9HLyr/1XFn6mUu2s7uJwJEAvRwJkkQDdDQnQy8k7X19Z+BKgByEBejkS IIsE6G5IgF6OBMgiAbobEqCXIwGySIDuhgTo5UiALBKguyEBej kSIIsE6G5IgF6OBMgiAbobEqCXIwGySIDuhgTo5TTpPXO4aBOB Lz6Gpmm470UJmUtcA/KPXYDyWZUA3QoJ0MspF5EfQQJ0K3Y+EQnQ3Wma5vv9ugKGv6y9 Std1JVdJga1+NicyjuM4jsMw4EZ4xC49xSYwTgJ0JyRAL6e5JA 7O/oaNpepnq4ME6G5IgF7OZQK0PyqrBOgHkQC9HAmQdwnFJLsVEqC X85Qu2FGJVL+EWIUE6OWUO6EtiMrcti0+g/Zv5GbLfie0m3fa2JlICO6l6zr4uZ0E6E5UFqBr3s+/yTiOLhuO/jf5fD5931+ztbRYpKluAUmADmQYBlgrmEz4+Xy6rrsgCjLE7ii QIDSCHw7BKnKr7XpuQGUBwtTVnYmIaZrGccQGGADdrtqZuiPQS k6YVkFVBDOzKu+MKgHazzAMWDnRJrbfESGQ7HbexVDldj1u6+7 bRAJUmXEc4VtVE9qMcw5LyTRCfzESoAeDF/j3+/1+v33fa7urPYzjCFPo+/1Kxy8DAqQu2PMYxxEv7Wt8zD8Ce7IS9GuAAGkU7GFQfVY9uWEY UNqYEbO4m3tqyk/q5A2jXRiHcvNUHTfvMd/3fTdTnoeQDa9W+vLbtpUGnY0E6HmsVR84OLbNlzn8zCogVlHXd eWFjIbx/X6lQaciAXoYUJ+SkWPYDmyEZ7/PMbZt43h4oTBqAcMKfvpmnmldkjGszpcGnYoE6EkMw4CX+eJpN HlazbUz0NPclHl5UODSoPOQAD2GcRwX1YdD8heYPM9lGAaW0qI MyQ46FQnQY+i67vP5ZLyqeF1LesqhdyzfAAoNT7EBCdAzcM7lv c6wj9aOi4lpVvb8FERo0Co3tihBAvQAIC6Z2l/SO5vMMPzhYEEfxs4Zu8OOoO8cTd8MR/cX+1mQ78xp0CmZlsdyCwH6fr87E3k38IOmvi1RH0yY9oalG7Mb DxQEf3kQbRifm/TGOxv28DkEb+wfGfj+pTUrTtvsSHyhBuXLWaxFAnR30PlKuX4W 1YfSs2fCNGpJ6ir7l/OcCnbIwPxGqFLGjwY9TRXUoikq1nILAfp8PjsTeTGZGr/YHtp5nffOjgNn5aVmM58kQNAOTC86JEHMooL1lEoTFl/q2/z7QKzlFgJ05/dnXfLVHX6W6FeY8HKUz8IVhFXcfxWCzLdmFuWGqcwZOE8qOri+ aFQemBNxCwFSFyxFxsDJaBMmuRw4dYVzYS6wgGikeJdjtKOjLp Rx+uQ1SEbQgdxCgGQBRclX9NR7mF2MA8drIEDX+IAyNRJrRA+0 Pjh3ISxkXCs1Ni8j6CgkQPclY/6khmNg+xweVetKAcqH6D0jgC/iZ0c1KPUCkBF0FBKgm4IqHrVi0HcIn1lmsty2iPG8OgL3FgrQt tk6/Hm+n4Ue356biiYLrfG+zfj40U+UEbQfCdBNyfggUvZ/xuvsNm3Ow9HJVQK07UK0JsoFaNtNpVQj6ovMGEGY36B5iTuRAN 2U1FNJmT/5zhcfcznwJeHnawWI849L8DYLXCVA+Q0XMYqPv9jbJ9ODizqeM 5YOuqV7Wo6YJED3JPNUbAu05HsEbr2bBrrAf1cJ0KoLeTe7SoD W+oPQ48vnxBNxeKOjRpDXeRQbkADdkUzTiva/Fp/iBgFCw+O/vyBAU6xjlTGCFlMTi0iA7kiqZqf6X4stYYMAhbLyCwIU7Vilfg UPkdxAe5AA3ZFUVI3o6HtKlSwZAXKJleJHCZA3VhX2ZQ4XIHtF 79ZKbJawkFO9MORcY2F7qC9Anq/hraCgy4O3Rx9JtP9VEibCORddcMdcpb7ivzjNbqTBgBvWXT0FA uT+jlVhqb29u2MFKLycFY4SAXLBTlWZRqLB+J1IgC7CaxjbBCg ai768UYXHGZk09Xrnv4sZtmeG6djgHt4VvSqYn2qYFyDObKZKM hIATigpq9DpgyPRH2LqQ2YkziN/6R+kvgD9SBcs47DwnkHqkaSObxYg+DtAypTIJxslKkA2fW4kbU/gfeUXguYFKLpWw06PKnQbh6elftiaFbMlyFzyqC9Amyv6s1glQ NEzU48K+zIvXj0sZLow0DEs+UkJhQLEpniUBQTzJ5xMiBD0+Fw uQF46zrnokmkIEA0cLgMehsHrFIflICYJ0GWcJECFzy9ayAh8k 085n2yUpmls22Pfk2EVm7+umaMEqKSFFwpQ+AjyAlSSBwlQFAn QRZQLUGqhaTSFzQJkXTPRSBeHC5BHqst5EwHy/Pqp0igXoGnJv/6bSIAuolyAUo0kKkybBQjuEo/8Twrx8uOCaIq4NOf7HeUDSm2e48zK9XIBav5OiZYAnURY1GuRA BWxX4COtYDgmm0NXvM4VoC8nFsj6CgLiDfljejRTTOtFKCS0vD GcPNxSyRAIbKALqJcgDDXJnWa17oKPQteIUfbCayS1E/KWRQg9v5wL4X6y98ujoLZyQowfzjRaZUAlXTBJEA7kQV0EWgJb QxGIOW/0TgP0XdFYWAar5C9dV7Rg6nn4s3QC/PZxGbxhaRGwfYI0BTrWlqbqFCAwvKRAJ0ESmzP7AQJUBGpdpgi NEpTWlPSqBBPw/4kTGccx77vvcGpxbsIuzxe5qO7IYYm0lECNM1aj+y1bbt2JvQU m5sWlexp/TwgCZCHBOh2ZHrFXtPlwZICXFvIqYGzEE+DUpnPX+hAAcrQlu2 AEJ6WKmROJS9kj7PjleRtxhIkQMcTFZopEYAmdFhE2SlAfNXbD Q7Z/Oyg9c0FaLEcogsvUq5xGTX7kQDdjlQjRPwH72Bq+NljpwBBaEL nFM0iKsjTBQi9Le82U42kOWELgF+jsgAVdst/iqiPZkoMhE1lPYtDBCiqLC8ToLAwU+9Iz7MmtiEBuh1tervqaG 8L7SqzS8xOdwnNnGjK9it06VfF6EI/jj9B0I/MyfzWfi4kuljMAge2J6BYLheeHDVIxVokQLcDzTgVhzgsLryKM 60xMwkghe3WUWVSG/hRgNYO9hEmmDegrHcMErnqphbreujryW+CJKfyTlB1a46CSYCi pNw6qeh83t4SHht0wbYu/tzLkh3w3nwhL9m8AHVdx28zI1CcWgUaM80qI9PREKuZpXmKx7q f+jOhJUBR8r2w1KbMJ+1U5ebAHRALayUhGEhznCskXx3bxPjgf hDNw5OnjJlTEgVFLCIBuikwTVO9sNQzw3v+cA1iLUFsHa6ex7W OHcesJUDRepgxf3Y2GwEkQPcl5Y7FRJXMcg07VecQvFqCTf68b 4+6VhUBamObysImil4uJUxiLbcQIA0lRMlsiUehCb/yAp4eQuZyU3qZwjaica/J4X7fcRyj6jOlVQb9MvW/DuEWAqSXSQq4oqPmTGYvZgwbH1uqSDPcChnqc2BrRBcv+hWuda AAMYh9VH1S1yrZhkQUcgsBKlme85vkmzdiqmbk6VgNwrLS6JDT sa0xNb5+7B0hwWgBZor9cMH9cW4hQAca8O8DrTHawtEXyGsQBm sOFAgXcFTK3lVw43abnaOaPYbbU9KZ6WEVrnoR5UiA7k5+kqGb A26ldjdlSztWhp4F90pFWWX89PnyzIw/im1IgB4A3CIp+ci3GUT5oQwtTxY23R84fQp3c1070/oMkGHknx+Yf0bg31aS6nydgQToGbSJkRqQ2hLLnmB3VT4Dbnla qFb4u0oZN4P50yW7V6cKOd/bFZuRAD2GtkCDPp+P9t7cANQnM3+qXVruK7YhAXoSmWGvaZ7S0 sw7c16ct+eSX0Y3zVVUna8zkAA9CZo5GX3hPGlp0CKY0ZMvz1a O5zORAD0Munvy+gLHsw0yLywl0jPJ9jkfCdDzKLGDpnkqDby8f d//8jscw/CcGNXENvMIkfpcgATokZS7nO36dTsItTi4Xjj6bs/fOVZlx8K+hmaO7LMqP1Ha2Nap0ULD5X5Zta9BAvRUxnFctd4CS rRTI0KQJv5Cs1ozB+cmrOqHctWbeq8XIAF6Npgd12pxwBE45xj qSPN9rkEC9HgYUOLwMEC/A8xJLvevnZ0fQgL0ErhUfW2P48dBz5SdRyn4xUiAXgVXn2rsZh FKD9xVUu0qSIDehl19iviBeqsTjMdjWRwj6qt8KiIBeid2EhCV KATzg/i56zqOlPV9v2r9KhZ8no3NMI94OUfm7V2wkwVg8jhJ8w1wEqDX E84D+kG4IF66cyuwB6cESOyFQb+iDMNgT6idWXEXJEBCiJpIgI QQ1ZAACSGqIQESQlRDAiSEqIYESAhRDQmQEKIaEiAhRDUkQEKI atxCgDQ7XojfRAIkhKiGBEgIUY1bCJAWKArxm9xCgHYmIoR4KJ UFCOFadiYihHgoEiAhRDUkQEKIOozj2DTNnh0BJEBCiI0gJvSe FCRAQoiNSICEENWQAAkhqiEBEkJUQwIkhKiGBEgIUQ0JkBCiGv UFCJt270xECPFE6guQLCAhfpb6AqTV8EL8LBIgIUQ1JEBCiGpI gIQQ1ZAACSGqMQyDBEgIUQdYQHv2pJAACSE2goBkEiAhRAUgQN oVQwhRBwmQEKIalWNCS4CE+GVkAQkhqiEBEkJUQwIkhKiGBEgI UQ0JkBCiGhIgIUQ1JEBCiGpIgIQQ1ZAACSGW6bqubdvv9zuOo3 Pu+/12Xdd1Hb7Fqi58/nw+bdu2bYvjXdf1fZ+a7iwBEkIsAB3Bh3Ecv98vjrPxfr9ffm7 blgvcIUP2TA8JkBBiAZg8tIBwcBiGz+czzYqDz/ZMnDaOY9/3/NdDAiSEWMA5RwsIH9q25ZGmadCQ2SObpqnveyqLcw7yFCIBEkI swG4XlKjrOuvTcc5BYoZhGIYBgtJ13TiO7ILxg4cESAixTN/3fd9DR1qDPQEf4K7Gv845nGaNI0tlAeq6TgIkxM8iC0gIUQ0Jk BCiGuqCCSGqUVmAsDFQ13XOOYzbgb7v4coCdIClQAoXk5rcicl a+DDMTNOEAQL+1v4bTXxzxkr2OeE59mTmnJnHtFebK+9Iviiuw SttfIgWdcVMiii36IIJ8SNghh74fD6fz6dpGvyLD/vT3wNzyL/I4TaQQgbcb2UBSk2RXEX0tbyIfWFu2B1t20W3wXyWZGyD9YS+8 GZDEvapNVq7mX5mW8rHUtgOcfIZ2d4kC39gqYaZtOVfEeawJD/1BahNzFASV+Kc21kVhFgLZlFX3pZHAnQHJEDielDr9qQgAXoJE iBxPRIg8Q8JkLgeCZD4x/UCBCcl/0XQBrgw7VQAODLtQc+1yfzTA2qD0YRn8kLhckpy9r0LIAES/7hSgDB2g5FaHEE0maZp+Bcign8xVsJ4Dt5Y7zRNwzDgBJxpw2X Z8eBpDmHD4zaghJemuAAJkPjHgQLEiZcpwqaOq2P9NLQJQ8vUC B6EWHDhNcAcAmSeSdk0o2fiM+ZShGeKC5AAiX8cJUBo1c3f2FR RPAvIzRO4oTWYkeTJStu2+IBZfN/vF0pnp5OEZ+Ivvm3N2kNPqtiD21kCopz9tU4C9BIOESB0hQo7M tFz0EVCFwxKFJUV9rZwJg8656A44ZkwdjjfErGyvDOpVnsKQZQ jC0j84ygLiB6WxWYcChAUBzriZYkChM+ercTPzexF8ioVe3N0N pG2ba39tX9urihHFpD4x1ECBMvCG2OK4gkQ7RGOYVnXDAVoGAZ 4giYjK5NZUsuDWJoQnjmZMS+kzyiiB5aDKEECJP5xfcMLndCNW UvpnEOHDu4byBOUgv0m9Jh4EGfCPcR+Gc6E1WP9zRBKnEnPNCI f48zLyuGXeacA4eVWN0DE47hegOxOUhQg2zPyjnOUij6dz+dj4 xDzIO8iPEiJsWl6/TINh13G2wTIm+WBMP1HJb4qG3sU0GuNtpmVXBrv/G0XvWHXA2ZLeHzPk42+onBQts+V3EKAmoPmfXE6Gfv/jZm9dhQlMTGsx3QDHJTBlF/cVGHD2Hzp2wqQeDGvEqCw7bVty6kifd9zli2dke0cdSk0+xksK mq9Wzuffge4SIdhwGm0XOwRXhqrAXCt8FVsn4od62lN/DbrnWVfY4PRFL2oEBdwCwE6atoFGme04XF8F1vEeu35+/1SnujRxDlo2MghPiP+E+RpMmrFaSlWbuhJxQnhpaP9RDv6Q9Xj qI31qk6mv/b9fplhCZB4BLcQoKN6SZkZHPiKkYOpKfY4y8KzpNC88QGawvZv R2em2aixIzWTkS1emttpp+Qy9MgitwzASLmcArtPXTDxIG4hQE dZQLapA04wo4gA/htOzM8LUDMvAgCc+OvlxKbg9TH5b6bvaa0q61Gmix15aMy4sgR IPJFbCFCqHa6Fk0HwL8dWOekedkpoAdmfZwSI3a5pHuea5om/TCG0gLxLMxFrfEVvJBQR+xNOV5EAiefyKgGa5mYZOlysIwaSYR 0x+O2iANGRZFcMwexq25bfTkYK4ZNu/rqfopaRJS9AXdfRFx7m1l56VdHtHLkTYgNvEyDOam3+DjlN81h V83cAC14bfMYMGmw+AUEJz+HeZJzjHx0ao/HFYbXoKFiq74mchO4hXgtbDnC6sHdy13WQ2lVFJwES1/M2ARKbuVKA2ClmlIxMTqwla73426AdSj+aF3/De3lMZol/pnCwQi36VaqGt3/ZEAakpO3Y+101MMr38dpcrUICJP5xpQDBEcbucNgwrGvfNv79m aTwseV7V7dDkN6RzHWtp8/DrnQN79FOQ1urQYtth24BzyNRggRIXMqBAoRgz6mp2zAo0BJSF +XqUDZ+61zjDEwuu2nnkBqerZTyo2VqvBUgZ2KYMTWab+hQ87r NPKULPW4GM0qN81qNs5Ydw2B7PX3YMpjtZSOHMEuhuNgREu/fMAI3FQcz3YZhsFdnlihJDHvQblr6Y0tbAiQOEyDrg1u8Yspws FMuoTiNGc3EBvZ0utE3D2mztlLYJnmym0ldmklxTrwdPeBQALS PvTlmknqUquEpAeKwhh2y4ITYcC4rrx7eC0/2vmLUNyrp9Fd5WfJ2qLc1OylzPLfdt73yDwmQW1odGt0s4WwQD/Syy2U4SoAaQ/7W2EpRoa0i0H7BlEsrQ3a8D1ix4OwEnBw+SqoDSZUD3+1Wj2yE EGfmo1vDigplrziZWRrIVRNAq9CZkNW4r8bML4ExMpnuZJOY0R quzUbKtnC8CNwcP40OCvO58GQ0K7d1EW99AUIp70ykhMXWxQ7z 2QJkh6iibaAK11tAk2lj9vVrJzpxNwv7cp7MgCBnRVjDB7IV7f h4FtCi8WX/evm0EhYKEBsVBcjryrGUUB9ssDSrGlYEo/dixSuKc46uaOhOqMLhVTwB8k72rv79fiVACzR/FzRgUTuroB3htr1uz3zF+ZR8/pbnhLEjcIQVnUMqOOJtIBHG8eC1ov2FA7nMB+R1jnjR6IK4sLr b93PomWZfJtUmC31A7d+Q0jxoe3mpZL1G5dn4fL4ULwtnyXIGG bp4njTA3mnn1TyN2cjIy5U3E6WZjTuKC4U4L0A0+tg6WC3tC2A t9QUIxbczkRL4vFmxqN92ASqKwwuubveZskvkbTpwSfKzdRPag/a6NlfWdxCmYKcanVQ+BwpQHmoEOrwppeATsb0G3j5bBZfFMed8 ClEFLBcgruDxrAPm2XYJ8RmGQF6ASFSA2MWDD5jp2/lfXk549fDZMQK/7at6USWtGEUFyLrbeCGrSl5XcVUVqqvNhDQAABsfSURBVC9AyM HOREpo/jrbUFds2dmqab16fIrTXGng76QAORN7yBmfaPiQ8OKyDYm1kI+ W/gubKxxfbDx7SA0bnQFfmyn1AXhX43N0viU6aBAyfpVXUjbC1EW tjcOT7dXtq4JdD4RAQP/dG8C2E1kt3hCVl8NmDrHCoTFbYrgoSsCWlae5XvjHJhZVsokZk tNfaXDBgONk4tvYgxKgJGzqXsmGAuSZ2facxlhDqV6A1yNA/bNmqn318XP7d2kYw5Xa484MQp9URNcI0HnwpaKwqgQvy7CR271 ADryWBCiOZwFtEKCwK54XoDASULkAeZ5Lm1sJUIaTwmCKQjK+v yi/JUCFFtA0GyB4P1g/xSoBsnphe1VWgGjp2LCHdARMMQE6TyNeIEBnvNXFeUiA4gLkTa Bgs9wgQB+zM6d1KDaBE9pekTmRAIkX80MC5MyIuzeaGI6m8ycu GBS3/3IaYZiOjZFIp7U9geGi7UXhrubGe94JZ7/erxQgjPKwcNb+HM61wqJIuYH5xO00yPCJR8vcO40/5JMVJfyQAIlFLhMgbqPsmXvlrKq4qYFwznK0Q0LAji5FL2T70Z wqgalhO1vUTyEBEv9zmQBh+q8d2rNxLEMzJDzoVVznHIbJaarY hTV2B0SCFJCgnTnhzNSYqUCAuErLjmDKC16IBEj8z2UC1PwNC8 eOred6sy5576CtuOEEznD+S1jHsLATnz2V4Vr88Ct7C808Vccr tP2N6neQAIn/qdIFwwxyWiLeFHAaMlwB3/wdSXBmYYfn/ufKm1CAvJkWYReMJkxegKwmkrPHCt6EBEj8z5XNhspiGzw+Y1I vJ6MzGI21ZTwBasyaGG8CxBTzAXkawenm2FgtDHmREiBe1J6QW i8mQuoLkJ1uL+pyTbMJF9ayy9OYndeAnYdFrZliFpAdw/IEKPQBRQXIepSa2OQMC3MSXQsqASrEe1IbkAC9hMs8F1zcyFVU 9EmjVWMsCU5lGz6RCz6nWbPsujlGmUBMv+bvKjwvNIftuE1mFq h1QuNbG9OLmjj+DU3tLQe3c0pFHgmQ+MeVrtPQ52KDY3kH2c2x uyGxV+VN4GRdohM6GizCGyz3poA2f6eeetDs8qakNn/H1DQbuwQ8CAmQuHrsBh0l+GtsW+XKSXuQXTZYH6nUvK+GYciog B0F40XDS3tf8dvoaTji7QclMqDW7RFrCdBL+LXBY2fmAR1IKhS siCIntPjHrwnQNE1htPb93CfI9yOQAIl//KAAiepIgMQ/JEDiem4hQI3ZBQXYjStDsNbG/tvME2q5+pz7qC1Sfmb0t24NyCE/WzbnIQqvUogNz4x/eTzMWzS3a4viEJBPXDqTN3v8+kx6MKQBwXHGS9iZ/s72CGwwBmTSZmwwLN5s/kLcvnFzVk8RoA2Ea3/285nBv5RFDKCcdNENYAsa5BN5C8eVhbgt9QVoZyKn4n6jb7LzN r2QOuHLHO9Su+5050yZbRleZU1YO2VPVjdnIJolRpWajIVyVPq rcsIP+ekRGdrd+yxIgF7C427zcRkWIfsfogToJTzuNh+XYREiA VrmRyr6427zcRkWIRKgZU6q6Da8tLeSYDBbP1/WwDbfJqI7n5HP/O1LgF6ABGiZkyo6/P/43P7doRiDa4xEcex1U2y7zfbvstJ23iGzPWJBpvVQtn+3Rd2cY XErJEDLnFTRbeuyG/Ug1APWSYYmgB1uSG3YsI0Nt2lD4XBVOoMTlu9akcLeYKPIp29E ArTMSRU93C2+MbFscJx2hJvjPzTz1uB2CtIh+8BsuE1vDJUahL uzwsR93Cez0TjDQnuXbv4GA7Mxoa0GSYBegARomZM2WhnnjZ7d HBwLV/H6Hc3fwKM4P1Si/cuvN1QF24v0oHYw5xBKN4c9hELZc1ICBGMKVqG3FZcE6OlIgJa BUpxR0Rltj+95Bj/GCZ4AeUGOMS2bsZN3ZuYMAWLOvVDzNHzgM1oUoEldsJciASrip IpODy6Ce1JN6I32mjHzEK5fqWIBhdNYmQ0v5+3f6MtebiVAP4s EqIiTKjq7J3YDhlBoUgKEZnyIu3faVBW4K9Y473NtxTQjQNYC8 mLIs2c6SYB+AAlQEedVdNuBoh5RTVICRD8uDagqAjSZ8Tuu2rX u81CA2COjuWc3/OLBqAA1fyO9axPkFyABKuK8is7tg6dpwsQfO6RF6wbbP3hBiOE wOmQIbNpRFXALWIXPn9v7Cm8KQkPTiQdxJs/nloQ8wQqQLKAXIAEq4hcq+uPa83mDA+IyJEBF/EJFf5wATb/xXN6NBKiIX6joEiBxPRKgIn6hokuAxPW8SoD+xmht7ZyUdl/c+wMr+jiOXJeAqcyZk7Hd8DWbTB0oQOEiNefcGXdxcwGiZ52cs WGhddU/jlcJUBPAvX25jffmlA+p6Bw+x5gRBqQzLfNiq+Soa+GZ2skB4S yeQ7i5AHFil50wcWDKL9gJ+oUChM+4Mawpx2yUybyZ1w5gH1XR ITq8Liby8a0Iewervexd8F879M65f13X4b72j8cfK0D2Tj0BYq jgnRd6hACtzWE0ChKKiw+di3gYNEoCtJGTBMjOyuXx8I1UeOeH VHROt7MH2TeBGJF2XjjOS3snfL9frqKyP9nD4QLEtzSzxxXz9i 6qZ/gkUgLUBFPD+cFO7ORMd1tieEvZCmyvwiW+tmxRc5jyzjI/lhcKEIwIOyvXEyA8eyywLmy0h1R0b06whXKJmoG64k2ARkfSVi me0By0GfmxAtT3PWYbImVYo60JvcbTqmf4JFIvvLwAUVNQMqwM mPntrXSxn3lC3/cM1TSZHrE7YheKY9k/met2AmQtAsayss/YmXUPVwoQ6gfaoYf7u9idu7VRgFxsQQMCoZbfxSLHCpCbw2jYT DJgEK+4xy1yq7YUQk2hBzoMruYJUFg57cncyygqQJ64RI+z5lx cFBneJkCZ43UFiDmhAcy1F4sCZJdoTkawbi5A0zTZXRKnnxSgV V0wr3LipRU+350CdMaAwGYkQEUpH1LR2RtHRHpa19Pcw4KmRCN 10YHtnGMQsvsLkI1nOMUeAZd9bXgtP1eAILs2hmSqcrLrjZMXu 2B8jbGSSIBy1BKg1LsllfJRFd3zC1ijxvoabXXBZ899mxpg2sM ZAjQZ9/mUdkJvqwYPFaBwR+/wZD5Wb/DBG7IIndAo1VRQAQmQz4GzGOxGNxYvkPuGlI+t6ByEDu86PO5l +NSNeo66TW9gmHv48gQ34/2kVoZPAjcePmVOBEGN5QvGnuzM1E1Mv/DCIbCqeKWNlO0sEzfHXcK/dp7HHbiFAO1M5GxuXtGP4nG3+bgMi5BbCNDNq9H9c3gIj7vNx2 VYhNxCgO4zMyrKj1T0x93m4zIsQm4hQNest9zMj1T0x93m4zIs Qm4hQJystRnMylsEw9iYKgrHHo7DdUcHnkcqh4UXLc+Y9y9z5W UsPOLhpVZIM09uLIR5QH7oRqWXndDbeiyrMowy8bzdZ+QqD6/LPMD858ILm6UN2dvZHqN427HxQovZW+zZ1J8J3ayH+2qyvXFxu RDicdQXoJ2JnIpzrkl0EjnAbIm+/y92ckVfTbgXTEoI38CYfr05n9GiWAWsJC74XuyVZ55L/lfbwA1y+4CSHB6bgUVQgNYQPu9a+Tw4U83y53PS/4aSBL8iQDd3k+8Ht1k7Fyt4XIZFCLpge1zAvyJAN3eT7+dx7fl xGRYh+x/irwjQHivxETyuPT8uwyJEArTMj1T0x91mJsNRp9upq1jENiRAy 6gLdk8yGW5jk8tOqmnwYtgwTyUliXFb7meN3GI2w/4suTleAgPC3Zb6AoSS2pnI2agLdkMWBciKAkZbzrhBRkFd9asm mME0HbF9y/R3Zg1CvkRj4N2E+gLUajHqPXiZAHkvNs4Uw78crrYWB/a3af9uChCe5gHjpTEBUpA4PmC+a5jPaI2yAuRlBknhKygXf+Il gki4XrL87JyzP5/mGBLePfKItSKZJXZvsUC/3bFzlASoCAnQDckMDnB6qo2aBNNgMjYC9AUGAtotDuJkjhBjF4 qoBkF6ptkOshnjB6/BMz+0gDiliALknLOZcXNITP6W1wofGdUw9ILhZnHXSIFhgr2D9 uo2b9BBe3VE0ds8SUUCVMTvCNCDXF2LAgRXyDT7RKa5udo5hFZ BGB0N3+Irph9tYxQmCATO8QQomvm/M4H/jxzWznGgrZXBzV1grbDH1/d9tHtlY5jRYMEPbQZQDjaHtihYPtRie9fc7mHnZlASoCJ+QYC8 9nZ/FgVomlsUYuBOxl5AG2vmzWqmOT43Gi2jx9O/wxQ8PB2BGBUKUKYL5v2KugCgO/Dv5J+Xm+MlIgSaXb1kbRzvQtx3jPLqnYZkU3exipcLkDtoR+Az WmaYIHMbTFj///h5E7IfN90ps46RLRlLiG3nZfrrJWED4Mg9LAXu+TfNAQzD4Pm2 1wbfiqc7hwgQjRRkDGYaNCiaONbchteC5nrNISpA9lsUhWcoYR Fy6i5W8WYBim4EuI0zWqY3RErXwzTvomUX9dDiPU8gzrCAbIIM wm93o3ZmY8W1xnwmw2zJ3lZIYReD1Y+Napo7Vmjw1hTyrgL3h3 e/ELKdAmS90db9xPps99308LLKvqHtJE5zFywqQPbqdE5Daqc5qj crqgQoCc3s/VbDGS3fqxB41eQvd7aFcmz6bRBlnQM61iShlbHhSaUyjHArzIY 3ZsTA+GhUeBPYLhibH7tgdujH3qB3BP0je6HwnEzO7dYg9ONY5 7edKNSmQzuj2kNHbArcjJNy7zl3bBcMc5ToF2O/zMrunvEv8GYBQuWGKbE/qTNaPscdvLdWRoBO3VLuwNt0f3dr8Gx49lxK7vqaDL+McCOAe/JaAWKN33+H05kVHe+T5u/wU9gF4/H9YprhqNuEiTElrJ4p6H5OR1tA4im8VoAw8Wz4u7ffZs6r6OFE/ikxTXZ6jgDRy2MTRB/TzSFg7I3gyIYBXQnQ03mtADV/2bP/73RyRQ8Tz3TB7i9A6E5yiNfOpoWjFxNqrUczNch9TYZFRd4pQN 5sdNj/e1zREqBy4P2ByjTzLNvpr8u2MeN9e2ayZTI8zFsSt2aLPnhGNl/OJv76AHXXYAd/t3FHAYqOj+5x314vQGEM/Gme+R76hs7LyU44djsZraHHnb1jN0eMP8oHhI4tI/PT5eQN+mwmMwIlVnGAcbAzB2cIUNgyMYd9c4KnClDY8FyMKRbp +dicHH6bfd/bRQ9t29pZLW5e6knWPqNUhu1Mn2m97oTZ8OpPm12eKlbR1A3Je t4w/IH8iK/hcbeZmQcU/cp6HDAHgqOQ0+yigrnEn8NLBenkBDwJ0IHsrHUSoPfwuNvMZJg T+dCZ9ZaJpiZDszvAdZ7e3D/OVJYAHYUEaJnHtcxtPO42FzMM7xKXj7MvZp1TPGhXY1hbCT1fL uacDoocJoAEaJnHtcxtPO42Mz6gMB4rZwaEP2zmRaqhAEG/2jm4hwTocCRAyzyuZW7jcbeZynA7hxmzZ9q1l7YPZSfNhwJkLy EBOgMJ0DKPa5nbeNxtZobh4WD2FmRSa+w4PTtoUQFq/0YRxOJMCdCBSICWeVzL3MbjbjOfYU5WsLMceD7DQltVYsfNTln E2nobkmnnrA5hkQAt87iWuY3H3ebmDFt3TxjFXVyJBGiZx7XMb TzuNjdnmGvQ0FPTuoqKSICW2bmS4yn8jgCJ+yABWmbnmsmn8Lj 2/LgMi5BbCFC7Gy+Azk6YGodRvFWgvGi4PuskMGSDqJ1wi2LinAt WVLVty3WYq8CDWPsr5geO21SBnFFQixlGKSGT9nkxYOD15JsDg jfDye02FdrO9hiF+ZlmN7ybnfH5zJT0bW8hQCm4czY+o98erhR v550wBbDlJsTNqS9AOxM5myYdiMfNSxavzdEC9tVkR5fzZG5zk UKbwiuoneW2IcOLObRFZ+P+HPWIS0opddpR6W9mbSCkEguusgB Fd86+G3ta5oN43G02vzE48G4qC5B7wpbkj2uZ23jcbT4uwyJEA rTMj1T0x93m4zIsQt4pQOyy7rk3srOiR7vNXsa8cMVhiFL3d5t p9MbDIMd7wh4/rj0vZtg51yp86r15oQA5s+Ev2NmuSlIIL5rf6dQexHIk685o5k ha3hHv52HpObOMOyTvjT5cgNq/i87tqKU9DZsgb0g/k2FuysyJFGfLkHPOW4IvSnitAPFfLH3eGRO6UIC8fzNbaPMgsm fVh5N9GhMTCwpi7yi8aPRI+QM+VoDcPE8H/yIIIcc+cBD2GtejryXjhG7+zh31dkY8g0c4E27ICwUoDEJ+vQB NfzefSQkQGoY3zZobcjMFBAblhn/UptsKEDdcZILRrhAj1W8WoGiGrXYTdmmhgNzHnaaZ3UPdxtLHa egUt/O8WSbLeaqPGM+9IZUFKDTI94NWbeco7llIEdWIEAZCd84hojAq dNT+otXTBJsmcl9jnINmA+lhI2Hi3GWUhAlWESDEPLUP13aIvN LY/BJKZdhe105QYkh5/BB+ND61aLwxNwcJwq+Qc8iNPRPPSAK0gRcKEKx6rl2w+xlsS62 kjNp5QwXA+MHR1oWDOMfLmw0nyraBpLinKCWmncNlEc9zVN629 08JA+M4UvHtBm3NvN80WrJ3yxu8J5kXg70uygQdWG5MRtXgvom TcUXZvYPQHY4ehOjwRrjfmVjFOwXISzPjLChJrVCA7EXtqzUlQ Hwhs/mhSfA0NBW2Z7Qle3dh6XlHrhcg6+tBsYfS7+0cua0OZDIcFSae zIj0oduunTeAZLLsOYYHvWp2Rk1+PQf4Z3fm4AIBCr28a1M7SY B4pjWXPPmAYc82THdD9KLhkesFCGYa+4NQTy+EoNcpPlyAuKmO PRIKEJ4RyzYqQDR8ogJkTR7P9hQl7HcB31SAUMku7oLZ3hAuyp +jPwjHJ2Yn2XJHbwINwJvs0/wdfbeeiOmWAmRhgngi3HLLexyHCxDjjeFZoHNE3WmNOxw2JmZU Udn5PoCTLiVANuc4UwK0lncKkDflBJEi9qRW0jLd37AY7Hp4mU F+cDD8eWimcbAGjONozwmDE3tHwgtl8n+4AFk9hQ0CPfXyjGge axPPZ3gcR9pieBZcSGkHuVCesCuZh2EY8P7A4CO1hrWIKeDnsJ Lwjll7Fz/OOwXoWM5omTfkcbf5uAyLEAnQMj9S0R93m4/LsAjBQ3ybE/pYfqSiP+42H5dhEbL/IR4gQDdfQfMjFf1xt/m4DIuQW3TBWI0YENcZCsPiHr5RHDIz/R3GYn7q7k7HJe+pMMwbnO6Pa8+Py7AIuYUF1LyOm4dkPiN7dhY 4L/H5y+EX3YA3IsmMXRZTvF0DfoIpBcgkhueOSn8V3xn7b/5mo+HbvTSbOwhQiY2Tx85/I9wLAX8x3OvMphclcIpH4UXzdDP28/7bD/O8NmOs4sjP2n01NhTFYkHZz2F+Ms8lw7GZ9OhnbLFcmYH27+uc my+efdEUqS0k7Am3EKCdiZyKm5cU1M7Iubin9Wgel2ERsv8h/ooAtfceqtvP49rz4zIsQiRAy0iA7snjMixCJEBFSIBuyOMyLEJ eK0CIa0FX/M5qergAhQvEMKKP414sUVwa0WrsPnnHLr8+tj1zZ+HwoHcJeGo 3TGjIZHgYhrU+O0Y+tBxSvKmdEaIbCrRmxZlHWHQv4J0CxIiIH InYe5NHCxDLnSMjEBc3R7a3MSIaE33VzdN/MMBxRpb2J9XO8dgwCLJ4EBEL1pZwJsMuCAi1CAXIRsjf/9ChKdF0UEut8rq/8T08mE4qwSfyTgFqg9nVGCTenOBJAuRdAmLE6R7emXxUNn7Q4V naE7sWWEvNC4pkoxrhINsbw86uzfCiAHFZvDdxlHM4+S/DbzNZm7hn03F5fcYw4esk9bBslMUpiCiElFlo0B1YvowowAyER Re1pO62h/g7BeiQhuQleKoAhQ2VsWk8AYKxcMbilaMsIK8vg9hjdn96BsFz QUTBVf2mEgGiWLs5FCyFD62dbZ4/Qc+9nSOTMW94IvZ8TGJcfCKZl58zO/nY2IBUGVwXB9lV53VZTxDwCMUOm4s36N0C/t6nK/dCATrDN3mSANEB1MxRxyg3tCM8AWrm6cWHv8qOsoAsaBhe7DEW pjNRytD8VhVyiQCFLZwqz6bO4uVPWCG9Z4GDDDceJpLKZ+q+rO jYrEJT8JnRHcMumNX66C3b3VOsTX2f1ZcvFCDWM+/g2dvyrMLzATFvtva3c4hFK0DcjOHwOnSscLs5JmS4HQhaBePD8 7VsQ83uzLBtjZ6RRQHiwUUB8hLh1gBhIql8ZioPI+Tb7pg1Uqh uUR8QRzPYK/e+5W9tuM77jDvXF6AzdlMKXST39wGFx2Fgc7MX+6hsH+3YLB0i QAi66gVytErkPQ4YF2sHK/MCRIuyXIA8I3S6RIBoBlofWShA1pnND24OPWz7s56LmgLEIMUg lZ+LqS9AZ/iA0ADs3nJee1hLFQGazIao7IvxURUGil2bpf2i5nVYmLg12eCe cMYJvWF35rwAoRhtH4cltlaAPLc6qlaYSGb4PF956K/hEdsFY8aoLDSarNbwoL0cM2kVH1qWyc+V1Beg6CaW+6FjBT7Fn a6NywQo3EGYAh0qzrEbUdEtdVQ6hO5S2Dh2jwC6gTd4RvMCxJL BaVyRv9gFs94onoZXGnLrDQ7YRFL5zJeq7ZMC+s5tyVBuaGByu glXyVvPtDN7XkNDcdAbeqvLawVoMiOU+/21hwvQDTlKgOxOpLb87XHvum5TOKeSuut1/dCYvYPs1XpD7NM0ZYbtDySckciM2drLiQLImC1Vbn/AgzB5bOPCmXbbyztQX4DO6IIdjgTohriCYTuYA9zW/fv93m0izOG4v6Ng9xnwilJfgFKdkVvxrJa5jYcK0GJvAjvntLt 3Z3oKmEPEgHD38TdHuYsAWTsTHzjxNDTpo5xnWFqngGcP361Cs 7g2h2R9nwCJO3MXAXou9KFeFtOzhDBq56qIqBvCpy6G3aOjNJX 4NTFb85lkVnFmmNv9mSzJQFhu/IxyPjD9PdgHyvpvi+gBIVkLDZxFFkOC9n3PEKhh6MyTLroIMsP PhxSF2xSS1RaUd48lBXV4SFYPFBSLKMxS4dM8NZNt26IcWM3C+ LZnZyCUJMgExWtRFA6EPcH8aTX3BRNCiM1IgIQQ1ZAACSGqIQE SQlRDAiSEqIYESAhRDQmQEKIaEiAhRDUkQEKIakiAhBDVkAAJI aohARJCVEMCJISoRpNeeCyEEOfyHwqZ+Tl9lVhlAAAAAElFTkS uQmCCAA==[/img] |
Fuel filter flowing. I unplug MAF motor dies. |
I meant the motor still ran with no power when MAF was unplugged. In the other post I said it died. I didn’t mean that! Doh!! |
You will get a lot of advise here, all good!!! Most will ask some of the basics such as how long ago was the last tune-up? I would suggest checking the coil next along with the spark plug gap. Is the coil rusty and cracked? bad wires?.. Some codes will set if the engine is not in 'tune' Best to cover these before going deeper.
| All times are GMT -5. The time now is 10:43 AM. |
