| bobomojo |
02-04-2014 04:18 PM |
Strange Rythmic Ticking sound - NEED HELP!
Hey All,
Brand new to this Forum! I recently just bought a 2002 ZR2 Blazer V6 4.3L. with 107k miles. Only a few months after I purchased it I noticed a strange ticking sound coming from the engine just before the engine would shift (The sound is fastest at this point). As soon as I heard it I said to myself "that doesnt sound right" I pulled over and noticed the engine was ticking at idle as well. The ticking is very Rhythmic and is dependent on the RPMS of the engine. When at Idle it can be timed like clock work....tick...tick...tick...tick and as I give the engine more throttle the ticking is faster but not much louder. I decided to limp my way home and let it sit while I did some research about what would cause this sort of ticking sound that is RPM dependent. (I should note that I don't know very much about cars but I am very technically and mechanically inclined). After doing some research I decided to take it over to a shop down the road for a diagnostic. I went and started my bitchin blazer....thats her name....and she fired right up with no ticking noise at all. I hopped in and drove it around the block.. as the engine warmed up the sound started to come back stronger and again, fastest just before the engine shifts. (At cruising speeds on the freeway there is no sound...that I can hear anyways) I stopped the truck and popped the hood... there it was again...tick tick...tick...tick...tick.... It seems as if the noise is ONLY there after the engine has warmed up. So I turned off the car, and did the first thing that came to mind... checked the oil..... oil was fine and clean. I had it replaced a a few weeks after I bought it. It wasn't dirty and I still had another 1,000 miles roughly before I was due for another change.
After I took the truck into the shop, they said "it sounds like a classic chevy lifter collapsing tick" and that they would need to be replace. Again, I dont know much about cars but I know from life experiences to get more advise. I took it to another shop that my uncle recommended... they said the same thing. I looked all over online for suggestions and tried a few things myself to possibly fix. I replaced all spark plugs with Bosh Plat (verified gap), replaced and routed all spark plug wires the correct way, replaced the distributor cap and rotor. ( All these things I wanted to do anyways since i just bought it). The plugs didnt look fouled or messed up real bad other than a little brownish and some light carbon. The distributor cap didnt look to bad but the Rotor did look a little brown. The boot at the ignition port on the distributor cap had some corrosion on it too. oh, and I also replaced the Serpentine Belt and the check engine light has never come on nor have any codes been sent.
I cant pinpoint the ticking sound anywhere on the engine. If the hood is shut, it sounds like its coming from the very front of the engine. If the hood is open its a little louder on the drivers side in between the air filter box and the exhaust manifold. I went and bought a stethoscope and still had a hard time pinpointing where exactly the noise is. It was loudest near the exhaust manifold where the number 1 and 3 plugs are but again, at various different points. I would place the rod on certain bolts and it sounded louder there but then would move near the manifold and would sound just as loud. I checked under the car around the same area and it all sounded the same in intensity.
I took the truck to a 3rd mechanic and he said that it definitely sounds like a lifter. and to replace they wanted close to 1,000! At that point I decided to get my hands dirty and do the job myself. I replaced the lifters, and rolled all the push rods on a plate of glass. 1 push rod seemed to wobble a little bit so I decided that at only 2.50 a piece and while I was in there I would replace them all. The roller lifters didn't look warn at all and the cam didn't show many signs of uneven spots or even burn/wear marks. All in all, they looked pretty good. I did however find that one of my injectors on the #4 cylinder was melted back and was exposing the tip more than the others. I decided to replace that one injector and dipped the other nozzles in some lucas injector cleaner while I had them out. I reassembled everything down to torque, replaced all gaskets and o rings and also replaced the PCV Valve and t-stat. (might as well right?....thats what I said until my wife saw the charges :P ) All in all I spent around 400 in parts so I was feeling pretty good about it. I set the timing correctly at TDC #1 and lined the marks up...dropped it in....checked all my connections and started her up.....VVRROOOOMM! No problem..... I was feeling really good about the whole thing. I let the engine warm up and periodically gave it a few good revs. ....and again.....the ticking sound came back! SAME EXACT SOUND! still acts up after shifting. I shut down the truck......let it cool down and tried again.. VROOOOM! no ticking..... as soon as it warms up it comes back and its fastest / loudest just before shifting. The odd thing is that I can put her in gear... press the brake and rev the engine and the ticking noise stops but once I let off the throttle.... it comes right back... it slows down with the RPMs and ticks like a watch.
I am really hoping for some help from this forum. Out of all of them out there, this was the most helpful during my investigations. Could it be an exhaust manifold leak? Why does it only start after the engine is warm? Im at a loss.
Oh!, and I replaced the fuel filter and air filters, cleaned the MAF sensor as directed and made sure I never touched the sensor itself.
HELP PLEASE! THANKS IN ADVANCE FOR ANY ADVISE!
