Stuck in drive
Old Aug 18, 2010 | 10:41 AM
bobbo605's Avatar
bobbo605 is on a distinguished road
Default Stuck in drive
I have a 1997 v6 4.3 4x4...The other day i went to put my truck in park and i was unable to get the lever past neutral. The truck has the push button floor shifter. With the brake pedal compressed i am unable to push the button on the shifter lever in, it is rock solid. Has anyone else had this happen before? Im not sure if i should be looking at the shift linkage or if there is something else that operates that button...any suggestions would be greatly appreciated...
Old Aug 18, 2010 | 08:03 PM
There is a shift lock solenoid located inside the center console. But that shouldn't prohibit the movement of the shifter. Sounds like something in the shifter or in the cable has bound up.
Old Aug 19, 2010 | 07:30 AM
bobbo605's Avatar
thanks, you wouldnt happen to know what operates the push button on the shifter is it electronic or is there a cable? Im thinking it has to do something with the shifter...
Old Aug 19, 2010 | 08:23 AM
I can't recall how all of that works. It's been a while since I have had one of those shifters apart. Best way to attack this is to get the console taken apart and have a look at it.
Old Aug 19, 2010 | 11:59 AM
bobbo605's Avatar
Roger that thanks for the advice
stingray74
Mar 5, 2015 08:27 PM
mr.vls
May 4, 2013 03:45 AM
Havensk
Jul 25, 2010 08:16 PM
huskerinaz
Jan 19, 2008 10:53 AM
dcblazer
Dec 18, 2006 06:07 AM
