-   -   stuck in first gear (https://blazerforum.com/forum/engine-transmission-35/stuck-first-gear-20029/)
cagillman 04-21-2008 07:36 PM
stuck in first gear
i got in my 85 k5 ( 350 with a 700r4 ,4" suspension and 33's)last week and started to head to the gym, then out of the drive i noticed the blazer would not shift out of 1st gear. i went back home and found the TV cable broke off from the carb. linkage. i reconnected the cable and i am still stuck in 1st. i have also checked the governor. is there anything else i can try before having a rebuild. if i have to have a rebuild i am wanting to put a th400 tranny in it. will a th400 bolt up or will i have to make modifications? thank you
carpenter625 04-22-2008 10:57 PM
RE: stuck in first gear
,did that on a 70 firebird and it was the vacuum line to the vacuum modulator on side of trans,if not that,check tranny fluid and see if it seems burnt or dark,there is a $6 botttle of solvent that u dump in there and run it thru all the gears and then change the fluid and pan gasket,worked in my 91 suburban for a long time
Chevy Lover 04-23-2008 12:48 AM
Check the TV cable to see if it's operating properly and adjusted correctly first.
If it came loose at the carb, it may be stretched or out of adjustment.
