-   -   Swapping transmission and t-case (https://blazerforum.com/forum/engine-transmission-35/swapping-transmission-t-case-95595/)
Shawn Stunkel 10-26-2017 12:32 PM
I will be swapping the trans and t-case here soon in my '98 LT 4x4 (found used both for 300) and I need to know if, when I remove the transmission, I need the same transmission code or if I can use a different one that won't screw with the computer. I don't know which transmission code will interchange with what. It is still in the vehicle all connected so I can't access the tag or the stamp on the bottom of the extension.
Transman304 10-26-2017 09:27 PM
Same years?
Shawn Stunkel 10-31-2017 09:38 AM
Originally Posted by Transman304 (Post 681687)
Same years?
I'm not entirely sure, it's from a boneyard in Wichita.
Transman304 11-02-2017 08:37 AM
1 Attachment(s)
1997-2001 will work as long as the 97 has the bolt on bell housing. Same engine size. Look for year on tag.Attachment 36001
