T-case switch, go with GM or dorman?
Old Jul 29, 2013 | 06:42 PM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
Default T-case switch, go with GM or dorman?
i need a t case switch, should i get a dorman 49315 ? or a GM piece for double the price? is there a quality difference?
Old Jul 29, 2013 | 07:29 PM
chris015's Avatar
Not really. the dorman will do you just fine. Only things ive found to make a difference is fuel pumps,ac delco tune up stuff, and ignition control modules. Anything else is whatever.
Old Jul 29, 2013 | 09:39 PM
aa21830's Avatar
aa21830 is on a distinguished road
I like Dorman for many things, but the t-case switch is not one of them. The three prongs were too small, so they didn't fit tightly enough into the rubber cap thing and there wasn't enough vacuum to engage the front diff actuator. When I pulled out the switch to add duct tape around the prongs (sealed it well, actually), the alignment tab was broken off. Made it a little more challenging to put the cap on right.
It also failed quite quickly, but I did not fix the leaky t-case input seal and left the t-case over-full with fluid...so fluid contamination was going to happen no matter what kind of switch I put in there. But the GM lasted much longer with an over-full t-case.
Old Aug 2, 2013 | 01:30 PM
ok thanks, i will see if i can find a gm switch for a decent price
Old Aug 3, 2013 | 06:29 AM
coolasice's Avatar
coolasice will become famous soon enough
picked my acdelco switch up from amazon for 28 shipped
Old Aug 3, 2013 | 02:51 PM
wow how long ago? can you provide a link?
Old Aug 3, 2013 | 03:36 PM
coolasice's Avatar
just search amazon for D1754C.... they are 31.50 or so now
Old Aug 7, 2013 | 06:36 PM
ok thanks, just curious, did it have a blue paint strip on it? and did it come in an AC Delco bag? thanks much
Old Aug 16, 2013 | 10:52 AM
coolasice's Avatar
came in a white/blue box labeled acdelco, dont recall any stripe on it tho
Old Aug 16, 2013 | 11:34 AM
TZFBird's Avatar
TZFBird is on a distinguished road
Not sure if it makes a difference but I noticed Dorman makes two versions of the same switch. There is the number listed above which is their HELP line. The other has a part number of 600500. This is the one I recently purchased and should have installed today. So far I've been through 2 of the 49315 HELP parts in the past 3 years so I'm hoping for better results from this one. Dorman website shows 600500 as an OEM replacement. I believe the price was the same or cheaper on Rockauto than the HELP part.
I'm also dropping the transfer case to replace the seal which is part of the problem.
