Temp Dial is Incorrect
Old Dec 14, 2010 | 07:49 PM
Mark_D's Avatar
Mark_D is on a distinguished road
Default Temp Dial is Incorrect
Hello,
So, I've had some issues with Dex-cool gumming up my cooling system to the point where the temp needle was off the high end for 5 minutes of driving.
I've since had the coolant system flushed (and filled with green) and the heat blows fine and the engine seems to be operating normally, but the temp needle only reads 155 degrees when normal temp should be 210 degrees.
I assume the rust goo did something to either the temp sensor or the thermostat, but have no idea which. I'm willing to do both, but with winter's short days I'm hoping its just the sensor.
What do you think? Sensor or Thermostat? Thanks in advance!
Old Dec 14, 2010 | 09:16 PM
AJBert's Avatar
My vote is the thermostat. Just changed out my cousin's thermostat and it "fixed" the temp sensor. Although, before I did that I changed out his heater core and still had no heat until I changed out the thermostat.
Old Dec 5, 2011 | 07:39 PM
Mark_D's Avatar
This old, but just to follow up, I changed the thermostat and radiator cap and that fixed it. 2 easy and cheap fixes.
Old Dec 5, 2011 | 10:28 PM
rriddle3's Avatar
Originally Posted by Mark_D
Hello,
So, I've had some issues with Dex-cool gumming up my cooling system...
...I changed the...radiator cap and that fixed it...
As we have discussed before, air getting into the system is the main reason for DexCool sludge (or believing that it can actually go '5 years or 100,000 miles' .)
Crossroad
Aug 23, 2014 03:37 PM
RowdyRick
Sep 26, 2013 10:45 PM
zakm0n
Jan 9, 2011 07:31 PM
wetdog
Dec 16, 2008 12:05 PM
