temp gauge sending unit
Old Mar 26, 2009 | 06:33 PM
ant2297's Avatar
ant2297 is an unknown quantity at this point
Default temp gauge sending unit
is there supposed to be any resistance between the sending unit blue connector to the vcm connector pin? im getting 40-50 ohms. didnt voltage drop across the connector yet. this may explain why my temp gauge is reading a bit low and fluctuates a little. all air is bled, no leaks, thermostat is new, fan clutch not sticking. how does that sending unit work? it only has 1 prong. does the vcm connect the wire from the dash to the thermistor which acts like a ground? do both ends of the wires come apart from the connectors?
Old Mar 26, 2009 | 08:45 PM
There should only be as much resistance in that wire as a wire of the same gauge and length. 40-50 ohms seems a bit much though.
The VCM measures the resistance to ground through the temperature sending unit. The ground is provided by the threads in the block. The gauge in the dash should be connected to the VCM and is provided with a signal for the gauge reading.
Old Mar 27, 2009 | 10:52 AM
ant2297's Avatar
thought so. im going to check the rest of the wire and connector today. does the wire come apart from both ends of the connectors just by pulling on it?
Cidium
15
Apr 3, 2011 09:28 PM
zakm0n
Jan 9, 2011 07:31 PM
Malachai
Mar 27, 2010 10:00 PM
The Cheese
Nov 21, 2009 04:23 PM
mboehler
Jan 16, 2009 07:16 AM
