-   -   Temp sensor on a 2002 blazer 4.3 vortex motor (https://blazerforum.com/forum/engine-transmission-35/temp-sensor-2002-blazer-4-3-vortex-motor-96593/)
Joe Gresk 03-31-2018 11:52 AM
I went to replace my temp sensor and the one that two auto parts stores is showing me and I tried are a bit larger in thread size diameter. Not sure what’s up with that? There is. I bushing or helicoil that was put into threads to fix them if it was damaged. Has anyone come across this problem. Thanks for any help.
Strangerock 03-31-2018 04:01 PM
Ive never seen this before ....usually a thread repair or helicoil will bring the damaged threads back to original size.
error_401 04-01-2018 04:47 AM
welcome to the forum.
I've moved the thread to the engine section as per our policy on the New Member Area.
