Temp switch and/or Temp gauge sending unit and/or Temp sensor? "w" engine
Old Jan 8, 2011 | 03:14 PM
zakm0n's Avatar
zakm0n is on a distinguished road
Question Temp switch and/or Temp gauge sending unit and/or Temp sensor? "w" engine
I read somewhere where some guy on some forum went on a rant about the "Temp Sensor" and said there was, on some vortecs, a Switch and a Sensor, and the sensor was prone to fail, even without showing codes. And when this sensor fails, it causes anything from minor fuel economy drops to horrible engine timing. So, I wanna know, is this mythical temp sensor tied to the gauge or not? My 95 W code jimmy (seperate thread on it running poorly) has a properly functioning temp gauge. So does that mean that the magic sensor is good, or does the gauge have a seperate sending unit? Also, what is the single wire connector in the block on the driver's side? Switch, senor, gauge, or all/some of the above?
Old Jan 8, 2011 | 05:42 PM
JPinCanada's Avatar
JPinCanada is on a distinguished road
I'm curious about this too. Currently have a no start 2000 zr2 in the drive way being worked on.
Old Jan 9, 2011 | 02:02 PM
JustJerry's Avatar
JustJerry is on a distinguished road
All I can speak of is a 92 S10, it has both a sending unit on the motor + a coolant temperature sensor. The sending unit works the temp gage, the a coolant temperature sensor goes to only the computer.
My 30 year mechanic friend at the Chevy house says the coolant temperature sensor and the connector to it fails quite often, that he has changed many of them out. If it does it causes all types of trouble for the computer does not get the proper temperature of the engine.
Old Jan 9, 2011 | 03:23 PM
rriddle3's Avatar
Engine Coolant Temperature (ECT) sensor location '95 4.3L
Attached Thumbnails Temp switch and/or Temp gauge sending unit and/or Temp sensor? "w" engine-0900c152802501f1.jpg
Old Jan 9, 2011 | 04:04 PM
JPinCanada's Avatar
Would having a bad ECT, that is telling the computer your engine is hot, prevent the engine from starting?
Does a 2000 ZR2 have an ECT?
Old Jan 9, 2011 | 07:31 PM
Yes you have an ECT. For other questions, please be courteous enough to post your on thread rather than potentially hijack someone else's.
Cidium
15
Apr 3, 2011 09:28 PM
The Mad Hatter
Jun 26, 2010 09:51 PM
Malachai
Mar 27, 2010 10:00 PM
ant2297
Mar 27, 2009 10:52 AM
mboehler
Jan 16, 2009 07:16 AM
