-   -   Thinking about a tranny swap (https://blazerforum.com/forum/engine-transmission-35/thinking-about-tranny-swap-29773/)
TehFattie 04-19-2009 12:00 AM
My transmission is slipping. Reverse, first, and third gear are worthless and 2nd only catches at a roll. We think it may just be the clutch, but i found a parts blazer with a blown engneine and good trans for a grand. Will the 99 4 door 2wd auto trans fit the 98 4 door 2wd with auto trans if both have a vortec? I may just switch the wholentranny? Advice?
swartlkk 04-19-2009 07:30 PM
Transmissions are the same.
TehFattie 04-21-2009 09:32 PM
Rats, that truck sold before I could get my hands on it. Is the 93 Blazer or 96 4.3L Jimmy auto transmission the same as the 98 Blazer? I don't want to pay for a rebuild when I can get another trans in a parts truck cheeeeeap.
Ugly_Monkey 04-21-2009 10:17 PM
Correct me if Im wrong but the 93 will be 700r4 or 4L60, 96-97 will be 4l60e, and 98+ will be 4l60e or 4l65e. Hope it helps.
TehFattie 04-21-2009 10:47 PM
Helped a lot more than google! Thanks man, that at least helps me kick the 93 off the list.
swartlkk 04-22-2009 09:13 AM
My ATSG book states that 93 was the first year for the 4L60E. There were improvements made through the years. You will want to look for a 98+ transmission as the pre-98 transmissions will not be a two piece main case (removable bell housing). Plus there are other internal differences pre-95 that make them incompatible with the programming in your 98.
