throttle body to CPI
I bought a '91 S-10 with a bad 4.3. I have a good '93 4.3 with CPI, wiring and ECU, out of a Blazer I had. What do I need to do, to use it, with my 700r4 tranny, instead of the 4l60e tranny it had.
What about the fuel pump, do I need to change it also? Thanks, Pat |
fuel pump would definitely need to be changed, and other things. I am sure others will chime in.
Has anyone have an idea, as what has to be done, for the 700r4 to be used?
bolt it up,get a tv cable bracket from one that had a 700r4. wire up the tcc lockup switch to the brake pedal so when you touch the brakes the torque convertor unlocks.
yes,pump has to be changed. |
| All times are GMT -5. The time now is 09:35 AM. |
