-   -   Throttle body plastic intake adapter with crack in it (https://blazerforum.com/forum/engine-transmission-35/throttle-body-plastic-intake-adapter-crack-57670/)
mrtaylor 04-07-2011 08:36 PM
I have a 1996 blazer 4wd 4.3l vortex engine. Check engine light came on with a p0420 code. I found a crack in the plastic intake adapter, the one that sits on top of the throttle body. So my question is: What is this plastic adapter called and where do I buy one? Thanks
cj97 04-07-2011 08:57 PM
I would call it a plenum. I am currently parting out a 96 and may have one available.
Zanders 04-07-2011 10:42 PM
go to any local junkyard, the s10/blazer/jimmy/sonoma trucks are pretty common to find there, grab one from there, though be sure to check that they didn't change the design on the one you would buy. If you want a new but expensive one go to LMC truck online they should have one.
marksoftball 04-25-2011 06:39 AM
MRtaylor,
Did the replacement of the plastic plenum take the P0420 Code away?
A follow up would be appreciated.
Thanks Mark K
