Time To Drop The Pan Again!
Wow, I can't believe it has been over 4 years since I last dropped the pan and replaced the trans filter! I have been driving around in 2nd unable to upshift for that long, lol! My bad.
OK, from my previous archived posts it appears I may have inadvertently damaged the 2-3 solenoid so now it's time, (long overdue) to correct my mistake as the blazer won't drive in any gear and I fear the filter is clogged once again. So, my question is this... How do I identify the 2-3 solenoid and is it a hard job to fix? |
If its the cylinoids that will be able to spot,they are in the front of the trans on the valve body They just pop in and out I believe.If you been driving the vehicle with these symtoms I hate to say it but your trans is probably toast.
Heres a link that shows how to change them |
| All times are GMT -5. The time now is 10:29 AM. |
