-   -   timing mark question (https://blazerforum.com/forum/engine-transmission-35/timing-mark-question-31006/)
dgh91 May 27, 2009 05:52 PM
i have a 4.3 vorec its a 92 i was wondering where to go by on timing marks i know where there at but cant see any numbers or marks to go by
thanks
swartlkk May 27, 2009 07:53 PM
Timing is to be set at 0* TDC. This should be the largest notch in the timing tab.
But you have to disconnect the tan/blk wire under the HVAC case just to the left of the transmission tunnel inside the truck prior to attempting to set the timing. You may have to pull back the carpet a bit to see this connector. Do not disconnect the 4 pin plug on the distributor.
