-   -   Timing TDC (https://blazerforum.com/forum/engine-transmission-35/timing-tdc-29060/)
thehustler211 03-25-2009 09:48 PM
Timing TDC
1 Attachment(s)
Im trying to figure this out. When my timing marks are lined right up on the timing chain sprockets the key hole on the crankshaft points to 0 on the timing tab like it is supposed to but there is no line on the balancer where zero is. There are 2 lines but neither one is even close to where 0 is. I know one is compression stroke and one is timing but it makes no sense neither one is on the crank at zero . Should i just mark a line for zero on the balancer and forget the other lines? i need to get this thing timed
Click image for larger version Name: timing.jpg Views: 0 Size: 4.4 KB ID: 139
rriddle3 03-25-2009 10:04 PM
Since you have already asked this question in another thread in the correct section, this thread is *locked*.
