Too much transmission fluid
Old Jul 13, 2012 | 09:19 AM
Debra Thomas's Avatar
Debra Thomas is on a distinguished road
Default Too much transmission fluid
I put too much transmission fluid in and now it is vibrating really bad. Do I mess the transmission up?
1993 GMC Jimmy 4 WD, 4 door
Old Jul 13, 2012 | 04:48 PM
chris015's Avatar
How long have you driven it since you put in the fluid? remove one of the cooler lines and start the truck up and drain some out. Warning,it'll shoot out like a cannon so it doesnt take long,easier with a hose,and a 2nd helper.
Old Jul 13, 2012 | 07:58 PM
warthogdriver's Avatar
yeah, i would disconnect the top tranny cooler line going into the radiator and attach a hose to it with a bucket and have a helper drain some out.
but do be careful...it will come out fast.
Old Jul 13, 2012 | 11:11 PM
xgiovannix12's Avatar
Chris knows this from experience ! right buddy ? =P
Old Jul 13, 2012 | 11:47 PM
chris015's Avatar
LOL shut up john. i spent hours cleaning fluid off my engine bay. everything was shiny,then dusty for weeks.
Old Jul 13, 2012 | 11:49 PM
I cleaned my valve covers since i had the coil off the last time .
Old Jul 14, 2012 | 12:36 AM
Rottidog's Avatar
OR a cleaner & less Chris & John way is get some small diameter tubing, like for a fish tank. Stick it in the trans check stick tube & suck a bit up. Put your thumb over the end of the tube & draw it out, cloth the end that was in the trans. Put it over a bucket & remove your thumb to drain it out.
Check the fluid level as per manual & keep going to get the right level.
Was I a rude person to chris & john?.... nahhhh all is good... wtg on the clean engines btw!! lol
I've done it too so stfu lol
Old Jul 14, 2012 | 01:30 AM
No rotti you were not mean ... I never did this mistake (YET) but I do like to keep my motor clean =P
good idea with the hose tho
Old Jul 14, 2012 | 03:32 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
A clean engine bay is a sign of someone who doesnt go mudding lol
Or another way is to loosen the bolts on the transmission pan a couple turns then CAREFULLY pry on one corner till you break the seal and some will drain out. But if your not careful it can be a big mess so i recommend the hose down the check pipe idea, its just slow.
Old Jul 14, 2012 | 09:11 AM
LOl cherry Its hard to keep any thing clean on my truck =(
I just wiped all the grease build up off them. Truck has not seen any mud in a while since its been so dry.
