-   -   Top mount / side mount? Distributor question (https://blazerforum.com/forum/engine-transmission-35/top-mount-side-mount-distributor-question-16851/)
95Blazer4x4 02-01-2008 12:12 AM
Everywhere i go looking for an engine asks me if i have a top mount or side mount distributor, Whats the difference? and what would it hurt if i got a side mount dizzy motor, and put my old top mount dizzy on it?
This is a 95 blazer 4x4 w/ a top mount distributor
Chevy Lover 02-01-2008 01:31 AM
RE: Top mount / side mount? Distributor question
I have never heard of a side mount distributor in a blazer with a 4.3L engine?
What's a side mount dizzy motor?
I've been turning wrenches for 30 years but I'm unfamiliar with this. I can only think of some 4 cylinder engines that have the distributor mounted sideways, driven by an overhead cam, (like a 92 sunbird 1.8L) that have that setup.
swartlkk 02-01-2008 06:59 AM
Referring to the position of the wire terminals on the cap. Top mount has the wires vertical out of the top of the cap while the side mount has them horizontal, split per the cylinders on each side of the engine.
95Blazer4x4 02-01-2008 07:55 PM
so can i just swap my old distributor on the new motor, or do i need to go find a new motor?
95Blazer4x4 02-01-2008 08:17 PM
ORIGINAL: Chevy Lover
Canadians... :P jk
swartlkk 02-01-2008 08:19 PM
You should be able to reuse your distributor on a replacement CPI motor if it came to you with a side mount distributor. In fact, you will need to.
