Top mount / side mount? Distributor question
Old Feb 1, 2008 | 12:12 AM
95Blazer4x4's Avatar
95Blazer4x4 is an unknown quantity at this point
Default Top mount / side mount? Distributor question
Everywhere i go looking for an engine asks me if i have a top mount or side mount distributor, Whats the difference? and what would it hurt if i got a side mount dizzy motor, and put my old top mount dizzy on it?
This is a 95 blazer 4x4 w/ a top mount distributor
Old Feb 1, 2008 | 01:31 AM
Chevy Lover's Avatar
Default RE: Top mount / side mount? Distributor question
I have never heard of a side mount distributor in a blazer with a 4.3L engine?
What's a side mount dizzy motor?
I've been turning wrenches for 30 years but I'm unfamiliar with this. I can only think of some 4 cylinder engines that have the distributor mounted sideways, driven by an overhead cam, (like a 92 sunbird 1.8L) that have that setup.
Old Feb 1, 2008 | 06:59 AM
Referring to the position of the wire terminals on the cap. Top mount has the wires vertical out of the top of the cap while the side mount has them horizontal, split per the cylinders on each side of the engine.
Old Feb 1, 2008 | 07:55 PM
so can i just swap my old distributor on the new motor, or do i need to go find a new motor?
Old Feb 1, 2008 | 08:17 PM
ORIGINAL: Chevy Lover
Canadians... :P jk
Old Feb 1, 2008 | 08:19 PM
You should be able to reuse your distributor on a replacement CPI motor if it came to you with a side mount distributor. In fact, you will need to.
ThaDopeShow
Sep 19, 2015 08:16 PM
jake kick
Apr 27, 2013 01:25 PM
50lb_cat
Mar 22, 2012 07:20 AM
Wexinlo
Apr 6, 2011 11:35 PM
90blazinchevy
Oct 5, 2007 01:52 PM
