torque converter?
i have a 84 k5 the converter went out im wanting to upgrade any suggestions it has 6" lift with 36s a 350/th350 its a DD and a trail truck
gears?
i think they re 373 havent had the k5 but 2 wks but i will be adding gears if they need it
Unless you have done engine work that would benefit from a higher stall converter, I would stick with the stock stall speed. There are aftermarket converters out there that can provide longer life, but you'll want to get your gears changed to at a minimum 4.10's or you'll find yourself in the same predicament again. 3.73 gears with 36's isn't a good combination for your transmission.
i have 4.10s just checked i will be adding a cam that is good for stock converters ive read that some people run irocs or vettes converters is that a good choice
Unless you will be altering the RPM at which peak torque occurs drastically, a stock stall converter would still likely be best. Being a lifted truck with large tires, you'll want to select the cam properly so it still maintains its torque at lower RPMs to get the truck moving.
