Community
Search
Sponsored by:
Sponsored by:
Tranny Problem???
Old 01-13-2015, 02:21 PM
newguy's Avatar
about every 6 months I open my tcase fill hole, drain out a quart or so while keeping an eye on the trans level. For now, easier of the 2 options
Old 01-13-2015, 05:18 PM
Red Sled's Avatar
Red Sled is on a distinguished road
Now were talking!!! Great Idea
Old 01-20-2015, 01:36 PM
princered72 is on a distinguished road
Originally Posted by Possum 6991 View Post
If the seal between your transmission & transfer case goes bad, it will let transmission fluid go into your transfer case and will overfill your transfer case. If the vacuum switch on top of your transfer case goes bad it will allow the transmission fluid to be sucked into your vacuum lines which operate the 4WD actuator & HVAC controls on your dash. If this happens you should replace all of the vacuum lines. This does not seem to that rare of an issue. I just replaced all of the vacuum lines in the engine compartment, vacuum switch & seal because of this problem. Hopefully I won't have to replace the vacuum line inside the dash.
I myself will also be double checking the fluid level on the stick just to make sure, but how do you know it was the vacuum switch. I check the transfer case and nothing came out. Can you smell it? Does some of the HVAC not work?
Old 01-20-2015, 04:53 PM
newguy's Avatar
Disconnect vacuum line that go to your hvac(underhood) if there`s tranny fluid in them, question answered
Old 03-18-2015, 06:40 PM
Christopher B is on a distinguished road
good information guys,..all is very helpful...thank you!
ski.dive
02-07-2014 05:18 AM
bouser
12-10-2009 11:46 PM
lovetheblazer
03-13-2006 01:00 PM
sting_da_man
03-13-2006 12:48 PM
nine5blazer
10-18-2005 05:19 AM
Quick Reply: Tranny Problem???
