-   -   tranny problems help ! (https://blazerforum.com/forum/engine-transmission-35/tranny-problems-help-51882/)
Crispy23 Nov 23, 2010 07:03 PM
my tranny shifts hard into second and slips out of gear every now and then. what is that. also latley when ill start it and dont give it time to warm up it will sputter when i drive it and then after a bit it with get full power and be fine . please help thank you
swartlkk Nov 23, 2010 07:50 PM
Vehicle Information??
Crispy23 Dec 22, 2010 10:02 AM
helppppp!!!!!
1997 blazer lt 4 door
swartlkk Dec 22, 2010 10:06 AM
Now that you have provided that MUCH needed bit of info, how about you go further to list what gear you think it is slipping in, the conditions (throttle position, engine speed, vehicle speed, etc) under which it is slipping, and any other pertinent details concerning the issue(s) you are requesting help with.
No one here can read your mind!
Also, you could try the search feature. The harsh 1-2 shift has been discussed before.
Another avenue for self-help is reading through the tech article index under which you would find this thread:
4L60E Information & Common Problems - Compilation
