tranny swap
One difference on the transmission side of things is that the 97 may or may not have had a two piece main transmission case (removable bell housing) and you 99 definitely has a two piece main case. The bolt pattern on the back of the transmission may also be different (square 4 bolt pattern vs the hex 6 bolt pattern your 99 has). You have to check and see. Other than that, the transfer case used has nothing to do with the transmission.
ski.dive
Feb 7, 2014 05:18 AM
