trans fluid
My transmission seems to consistently leak fluid needing to be replenished, but it isn't leaking it on the ground so I can only assume it's going into the transfer case. This possibility was confirmed by a mechanic, does anyone know what could be done to prevend this and what the negative effects this could have on either the transmission or transfer case? Thanks!
RE: trans fluid
i apologize i missed the post just below mine. Does anyone knwo how many hours should be planned for to remove the transfer case to replace the gasket?
| All times are GMT -5. The time now is 10:32 AM. |
