trans fluid leak
Old Apr 28, 2008 | 06:54 PM
pbrew's Avatar
pbrew is an unknown quantity at this point
Default trans fluid leak
I have a 1987 S10 Blazer 4X4 every couple of weeks trans fluid starts leaking from on top of my transfer case. The trans fluid dipstick reads low but when I take out the fill plug for the transfer case it is overfull and drains out. After lowering the level in the transfer case and refilling the trans, it doesn't leak again for a couple of weeks, Does anyone have an idea about this before I take it to a shop. Thanks, Paul
Old Apr 28, 2008 | 09:30 PM
Default RE: trans fluid leak
Sounds as though the input seal on the front of the transfer case has gone bad, allowing transmission fluid to enter and overfill the transfer case. Best to get it fixed ASAP before the fluid migrates its way into the vacuum system. You will have to remove the transfer case and replace the input seal. If you wait, you may end up with transmission fluid all the way up into the HVAC system! Not fun to clean up in the least!
Old Apr 28, 2008 | 09:58 PM
Hanr3's Avatar
what he said.
spend the extra couple bucks and get the double lipped seal, it will last longer and work better. put some tranny lube on it before you cinstall it. the shaft spining on a dry seal will fry it, and you will get to do it all over again. [8D]
the new seal is like $10
Old Apr 30, 2008 | 12:11 AM
pbrew's Avatar
Thanks for the info, Paul
razman
Dec 30, 2014 10:14 PM
Gkolo1
27
Oct 26, 2012 05:58 AM
AlpineFox19
Aug 18, 2011 09:22 PM
luthers97blazer
Nov 10, 2008 01:27 PM
harleybob
Nov 10, 2007 07:25 PM
